Hi all,
I know this topic has been done to death ( I used the search function )
I have an LJ with a turbo 186 that I need to keep cool. I currently have 2 x 10" fans mounted on the inside of a 3 core alloy radiator ( the pic shows the old radiator ). The reason they are on the inside is due to the inter cooler sitting out the front.
I am going to remove the water pump, install an electric water pump and upgrade the thermo fans.
I am looking for ideas on what dual shrouded fans people are using on the stock radiator size.
Alternatively what single shrouded fans are people using? I previously had a V6 in the torana and used a VN single fan which worked well but if possible id like dual fans that will sit low and neat.
I am not interested in davies craig etc. as I really want one with a molded shroud to get full flow through the radiator and inter-cooler.
Any advice will be greatly appreciated.
Barbs
