LH Tribute engine options
30 replies to this topic
#26 Bigfella237
  • 4,371 posts
Posted 14 July 2018 - 01:21 AM
Zero deck height is machining the deck surfaces of the block level with the top of the pistons @ TDC, and obviously parallel with the crank centreline and square with the bores. You can go below that height and rely on the head gasket to provide clearance to the head too, but that's usually only done if you're chasing every last bit of CR (the compressed thickness of the gasket needs to be taken into consideration when calculating CR as well).
Bear in mind that probably means you'll lose your engine number stamping too so ask the shop if they can restamp it again afterwards?
A dual plane air gap manifold almost certainly won't fit below a standard Torana bonnet either so if that's the way you're going, don't bolt the bonnet on and just slam it down without checking!
Sooo... I'm guessing you don't have a lot of experience assembling engines?
If that's the case I'd at least get the shop to install the new cam bearings for you (and clock the oil holes correctly with the new oiling mods). And get them to hot wash the block and heads thoroughly before giving it back (and even then don't trust them to have gotten everything out, ESPECIALLY FROM THE OIL GALLERIES).
Also make sure you grab some Plastigauge or similar to check the bearing clearances. And there's a whole procedure for installing the rear main rope seal if you actually want it to seal (youtube is your friend there, COME Racing have done some good videos on the subject). Remember to check the crank end thrust, and make sure to continually check for binding as you tension the caps, if the crank locks up you've got a bearing problem.
And don't forget to check the ring gaps and side clearances, if they need filing and you don't do it they will likely break on the first run (if they didn't break on install), and clock the ring gaps on opposite sides of the piston and not on the thrust side of the bore. And double-check they've fitted the conrods in the pistons the right way around (so the oil squirter grooves point toward the opposite bore from memory)?
And... probably a hundred and one other things I haven't listed above! It's been a few years since I rebuilt one myself but I doubt they've changed much...
#27 _MiddaSamid_
_MiddaSamid_
Posted 14 July 2018 - 01:35 AM
Steve that build sheet is ace.. I hope I get one.. so much info..
#28 _MiddaSamid_
_MiddaSamid_
Posted 14 July 2018 - 01:49 AM
Thanks Andrew, great tips.. I have built(assembled) a few engines, a bunch of small 4 cyl Toyota's, a couple medium performance Alfa 4cyl twin cams, a 276rwhp 308 and a heap of motorcycles.. I know the basics..
Dandy Engines is installing the cam bearings..
I'll work my way through the assembly when the time comes and you know i'll be asking stupid questions on here ^_^
#29 _MiddaSamid_
_MiddaSamid_
Posted 14 July 2018 - 09:43 AM
About the airgap... it seems they are only available for VN style heads??
What other alternatives are out there? Dual plane..
I'm comfortable with cutting the bonnet but it still has to fit under the scoop..
#30 Bigfella237
  • 4,371 posts
Posted 14 July 2018 - 10:05 AM
Nobody seems to enforce this anyway but bear in mind, if the air cleaner protrudes through the bonnet the scoop "legally" must be made of mild steel, which Torana bonnet scoops traditionally aren't.
From NCOP6:
#31 _MiddaSamid_
_MiddaSamid_
Posted 14 July 2018 - 05:53 PM
interesting reading.. how do they get the falcon shakers across the line.. proud of the bonnet and not under anything...
Thanks for that tho.. definitely worth keeping in mind.. might need a performer to get reg then go to the bonnet cut..
Been busy uncovering rust cover work from the previous owner.. he fkng stole my money.. I hope karma gets him proper good.. thief..
