Plenty of brand new R154 boxes from Toyota dealers and the like on eBay etc.
Prices are around the $3k mark, give or take.
They are a bulky box.
I could never find a comprehensive package, box and conversion so I gave up
Posted 30 May 2020 - 07:07 PM
Posted 07 July 2020 - 03:19 PM
I have a 355 with 400RWHP, 9 inch and 295 rear tyres. I went with a brand new Muncie M22Z Rockcrusher.
No probs at all and will handle way more than I will ever throw at it.
I have a bit of a write up about it here, just check out my other posts
Posted 06 November 2021 - 12:45 PM
Hi Guys, sorry to dig up an old thread but had anyone used one of these?Have you looked into a tr3650? As used in ba boss v8 Falcons and Mustangs in the states.
Posted 06 November 2021 - 07:57 PM
Definitely not a T5. I think the TR3650 is kind of the predecessor to the TKO, aside from not having any top cover plates the main housing does look similar. Bell housing availability could be an issue.
Posted 06 November 2021 - 09:46 PM
Looks like a 3650, maybe from a BA ford.
Posted 06 November 2021 - 10:48 PM
Talk to Jeff Dellow about a bellhousing.
Not much in the way of conversions he hasnt done.
I was looking at a box years ago, Tremec from memory.
I wasnt the first to talk to him about it, and he convinced me to look at something else.
He recently made a one off bellhousing for me to hook the LS1 and Dyna 5 speed together in my tilt tray.
If it can be done, he is the man to talk to.
Rob
Posted 07 November 2021 - 06:55 AM
Posted 07 November 2021 - 10:39 AM
~ He recently made a one off bellhousing for me to hook the LS1 and Dyna 5 speed together in my tilt tray. ~
Kinda surprised that hadn't been done before.
I would've thought Coasters had the same box as Dynas and I'm sure I've heard of people LSing Coasters before.
Posted 07 November 2021 - 12:21 PM
Think it had something to do with the shift set up.
Dyna is a tilt cab where the coaster isnt.
Even with the box and existing bellhousing at his factory, there were still a couple key features that werent quite right.
One I expected, as I had to drop the box down a bit because the engine didnt fit at the normal height relative to driveline.
Had to drop the cross member close to 50mm.
Manifold clearance took a bit to sort out, and even the clearance for the back of one of the heads was an issue.
Didnt get the bolt up for the slave cylinder quite right either, but went for a hydraulic throw out bearing instead.
Wouldnt have been too hard to fix that problem while I had the MIG out, but had been thinking of going to hydraulic throw out early in the conversion.
It just made the decision for me in the end.
Rob
Posted 31 December 2021 - 06:18 PM
Posted 31 December 2021 - 07:24 PM
Main Case CASTING NUMBERS:
13-52-065-001 Early NON-WC such sd 1982 Chevette
13-52-065-003 Early NON-WC S-10
13-52-065-901 82 NON-WC GM CHEVETTE
13-52-065-903 82-83 NON-WC GM
13-52-065-904 83-84 NON-WC Ford (Also used in Astro Mini Vans around 1986.)
13-52-065-908 85-91 World Class Ford
13-52-065-913 83-87 NON-WC Camaro/Firebird
13-52-065-914* World Class 88/92 Camaro/Firebird & 93 S-10 V-6
13-52-065-916* Newer NON-WC Camaro/Firebird S-10
13-52-065-921 91-95 World Class Ford - With and without the reverse spring anchor
This case is also used in some WC S-10's
13-52-065-922* 96+ World Class Ford & GM - With and without the reverse spring anchor
This case is used in Mustangs, Camaros and S-10s
Housings noted with "*" can have the fill plug in either the higher location for Ford and S-10 or the lower location for the Camaro/Firebird. (The Camaro/Firebird is tilted requiring a lower fill plug location) <photo needed>
The -921 and -922 housings may or may not have the spring anchor for the cantilever spring used in most of the newer fifth/reverse shift linkages. Generally 92-94 versions have a hex bolt for this anchor and beginning around 95 this anchor is smooth and round.
Posted 01 January 2022 - 03:39 PM
