lc cross member
14 replies to this topic
#1 bat 53
bat 53
  • 492 posts
  • Name:albert
  • Car:lc gtr
Posted 21 June 2018 - 11:15 AM
g'day all
would like to check if my cross member is not bent
the work shop manual only shows the 4 cyl one
so checking for square is not a problem but all the other measurments are
can any one help
thanks
cheers  bat
#2 DMLC71
DMLC71
  • 424 posts
  • Name:Daz M
  • Car:1971 LC 4 door
Posted 21 June 2018 - 06:51 PM
Hi bat
What are the signs that makes you think it is bent
#3 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 21 June 2018 - 08:59 PM
6 cylinder version,hope it helps!
#4 bat 53
bat 53
  • 492 posts
  • Name:albert
  • Car:lc gtr
Posted 22 June 2018 - 09:27 AM
i have 1 here that has a badly cracked trailing arm
the top wish bones had 20-25 mm of shimes in them
i can repair it no probs but would like some measurements
cheers  bat
ps paul cross member not chassie   thanks anyway
#5 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 22 June 2018 - 06:11 PM
Can't you use the measurement points of the chassis ,to check if the crossmember is properly aligned?
#6 DMLC71
DMLC71
  • 424 posts
  • Name:Daz M
Posted 23 June 2018 - 03:51 PM
My thoughts exactly Paul
#7 bat 53
bat 53
  • 492 posts
  • Name:albert
  • Car:lc gtr
Posted 23 June 2018 - 07:01 PM
yes boys
i have checked all i can by those measurements
but to my way of thinking the 2 top shocky holes are the ones that should be right
so can anyone help with that measurement
cheers  bat
#8 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 24 June 2018 - 02:03 PM
Id just put the front kframe back on the front and
weld up the lower arm..thats very common they crack
there specially if it has had a v8 up the front.
Mines cracked and so was my brothers.it will b fine.
Ive even heard of guys on fakebook that cant get there
kframes back in there lh-lx and have used ratchet
straps to get the back arm between the rails..
B #@$^%& we can edit..
Edited by madtoranajzedded, 24 June 2018 - 02:04 PM.
#9 bat 53
bat 53
  • 492 posts
  • Name:albert
  • Car:lc gtr
Posted 24 June 2018 - 06:22 PM
i understand , i have not got an issue with those parts
the part i am concerned about is the shimes on the top wish bone
25mm each side that is why i am after the measurement between the top shocky holes
cheers  bat
#10 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
Posted 24 June 2018 - 07:44 PM
Yeah ive got about that on uca.
Edited by madtoranajzedded, 24 June 2018 - 07:45 PM.
#11 bat 53
bat 53
  • 492 posts
  • Name:albert
  • Car:lc gtr
Posted 24 June 2018 - 11:28 PM
what :huh:
#12 rodomo
  • 17,999 posts
Posted 24 June 2018 - 11:36 PM
I have 2 here, if I remember I'll measure tomorrow.
#13 S pack
  • 15,539 posts
Posted 25 June 2018 - 07:38 AM
Agree, I've got close to an 1" of shims on the upper arms to get around 1.5 deg of neg camber.
#14 rodomo
  • 17,999 posts
Posted 25 June 2018 - 12:56 PM
One is on the car and difficult to measure, the other one is 787mm between hole centres.
#15 bat 53
bat 53
  • 492 posts
  • Name:albert
  • Car:lc gtr
Posted 28 June 2018 - 01:26 PM
thanks everyone measured the bent one
and 2 others suppose to be straight
all 3 are 787 mm :o  B)  :banghead:
cheers  bat
