radio turning off when park lights turn on
3 replies to this topic
#1 etorana
etorana
  • 246 posts
  • Car:ss hatchback
Posted 25 June 2018 - 07:24 PM
Hi All
Not a Torana but I was hoping someone could help.
My son in law had a stereo fitted to his Mitsi Challenger and all is fine until he turns on the parking lights. The radio then looses power and turns off. switch the lights off and the radio turns back on again.
Any Ideas  ???
Thanks in advance
#2 hanra
  • 10,832 posts
Posted 25 June 2018 - 07:30 PM
The orange wire is connected to the lighting circuit to dim the stereo display when the lights are turned on. Try disconnecting that.
#3 torana74
torana74
  • 37 posts
Posted 25 June 2018 - 08:55 PM
The clown that wired the radio used the park/dash light feed as  an earth!.  Disconnect wherever the black wire from the radio is joined to (i'm guessing it's going to a black/yellow wire now),  and run the black(ground) from the radio to a metal ground is the easiest way.
#4 torana74
torana74
  • 37 posts
Posted 25 June 2018 - 09:02 PM
Ahhh can't edit!.  But i'd also be making sure  the power feeds he used are actual battery and accessory feeds.... not a dashlight backfeed. If i recall correctly,the mitsu's have a positive dashlight feed at the stereo and a dimmer feed. Grab a test light and check whilst also switching lights on.  Not a multimeter, as the load will show on a testlight and might not on the meter.
