Banjo diff diagnosis
7 replies to this topic
#1 _Hilta_
_Hilta_
Posted 28 June 2018 - 10:09 PM
Hi guys, have had a clunk in the diff and appeared to have a lot of backlash, but today she went clunk and wheel shuddered while it was making noise, disconnected tailshaft and you can move the yoke nearly half a turn back and forward, nut appears to be tight, what am I looking at here? Are all banjo diff centres the same? Out of hq-Hz same as Torana ? Cheers
#2 rexy
rexy
  • 3,579 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 29 June 2018 - 12:05 AM
It’s time to pull the centre out and see what’s broken.
#3 Bigfella237
  • 4,363 posts
Posted 29 June 2018 - 12:06 AM
The only way you could get half-a-turn of backlash is with a whole heap of teeth missing!
There are fine spline and course spline banjo centres, but so long as the axles match the centre they are all basically interchangeable. You may have to get a couple of longer (or shorter) bolts depending on which case you had / are fitting though.
#4 I'm a Red Motor fiend
  • 758 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 29 June 2018 - 08:12 AM
Sounds like the pin holding the spider gears is loose and is getting it's end chewed off.
#5 _Hilta_
_Hilta_
Posted 03 July 2018 - 08:02 PM
Spider gear was in pieces, cheers
#6 rodomo
  • 17,997 posts
Posted 03 July 2018 - 10:45 PM
Burn outs? :dontknow: Or did maybe your foot accidently slip off the clutch once or 20 times?
#7 _Hilta_
_Hilta_
Posted 04 July 2018 - 08:40 PM
Got twin boys, but apparently neither of them were doing burnouts! At least there helping replace it! Lol
#8 GTR600
GTR600
  • 169 posts
  • Name:Brock
  • Car:72 LJ GTR
Posted 19 July 2018 - 02:21 PM
You need to take a leaf out of Ted Ball Pitt's book......Not the Torana!!.
I picked a few spare diffs up about 8 years ago at $50 a piece......see some people wanting $200 plus now.
