Urgently need a LJ brake proportioning valve with switch
4 replies to this topic
#1 Bathurst72
Bathurst72
  • 108 posts
Posted 01 July 2018 - 12:05 PM
Hello, firstly yep I f#*ked up. I just changed the shitty alloy master cylinder that was leaking out for  reco cast iron one. Got to bleeding the cylinder and for good measures i bleed at the proportioning valve.
So I removed the switch to do this. when putting the switch back in, yep f#*k up, I now have two switches and the best bit the threaded bit is still in the valve. The switch looks like it has been over tightened before as the bit in my hand shows signs of rusting across the thread where it has been cracked for some time.
So, I now need a complete valve with switch to fix the problem.
So are they all the same for disc and drum fronts?????
Are HQ ones the same and can I use one of them????
Has anybody actually attempted to easy out a broken bit before or I am I wasting my time???
PLEASE and help would be appreciated.
steve
#2 Bathurst72
Bathurst72
  • 108 posts
Posted 01 July 2018 - 12:34 PM
The correct name of the valve is Brake Line Pressure Warning Switch.
#3 ls2lxhatch
  • 5,330 posts
Posted 07 July 2018 - 01:12 PM
As above it is just a distribution block with a brake fail switch.
There is no proportioning so there is only one version. HQ, LH-LX drum/drum are all there same.
#4 DMLC71
DMLC71
  • 424 posts
  • Name:Daz M
  • Car:1971 LC 4 door
Posted 07 July 2018 - 08:16 PM
Just seen one on EBay
#5 meanmachine72
meanmachine72
  • 2,005 posts
  • Name:Jono
Posted 10 July 2018 - 12:38 PM
https://www.gumtree....alve/1189097838
