Uc axles into Lx banjo
5 replies to this topic
#1 _Hilta_
_Hilta_
Posted 02 July 2018 - 11:15 PM
Ok, I am just checking, if I have a fine spline banjo out of a Hz can I use that centre in my Lx banjo? And then use Uc fine axles ? Do the axles fit with no modes? Retainers all the same? Cheers and thanks in advance
#2 _LXT333_
_LXT333_
Posted 03 July 2018 - 12:03 AM
Yes to all that.
I have a complete diff here with all that ready to drop straight in if you are interested.
I just installed a 9 inch so have no use for the banjo.
I have to pull out an axle to confirm but I’m told 336 fine spline.
#3 _Hilta_
_Hilta_
Posted 03 July 2018 - 07:07 AM
Thanks for that, mine is plated for 2.78 but it has a 3.08 at the minute, will probably replace it with either of those, cheers
#4 Bigfella237
  • 4,362 posts
Posted 03 July 2018 - 07:51 AM
Yes to all that.
So axles from a UC Salisbury diff are the same as an LX Banjo diff?
I would've bet good money that they were not interchangeable, especially if the UC has rear disc brakes.
Edited by Bigfella237, 03 July 2018 - 07:51 AM.
#5 Max's SS
Max's SS
  • 374 posts
  • Name:Steve
Posted 03 July 2018 - 06:31 PM
I've got UC rear discs with fine spline axles fitted into my LX 2.78 diff.
#6 Max's SS
Max's SS
  • 374 posts
  • Name:Steve
Posted 03 July 2018 - 06:37 PM
There is a "sticky" in the Brake, Wheel section going back to 2011 on "Fitting UC rear discs to LH/LX".
