202 dip stick location
17 replies to this topic
#1 D-Train
D-Train
  • 171 posts
  • Name:Dion
  • Car:LC SL
Posted 09 July 2018 - 02:36 AM
Ok guys I'm lost. I put a black 202 into my LC and with the old sump put on it, I'm not sure where the dip stick should be. I've already given the old motor to a mate so I can't check. Any help and pics would be great.
#2 jd lj
jd lj
  • 2,100 posts
  • Name:James D
  • Car:LJ SVO
Posted 09 July 2018 - 05:31 AM
Between the oil pump and the distributor.
#3 S pack
  • 15,539 posts
Posted 09 July 2018 - 07:16 AM
Directly below the second last side cover bolt there is a boss in the engine casting with a small plug installed in the hole.
You have to remove that plug and install a red/blue motor dipstick tube.
#4 S pack
  • 15,539 posts
Posted 09 July 2018 - 11:21 AM
Edit: The blue motor dipstick tube as used in WB Holden's only.
#5 Ice
  • 15,123 posts
Posted 09 July 2018 - 04:21 PM
If your looking for the blue motor tube and dipstick i have them
you cant use the red motor dipstick in a blue motor is that correct Dave
#6 S pack
  • 15,539 posts
Posted 09 July 2018 - 05:48 PM
AFAIK the dipstick tube is the same for Red & Blue 6 (WL Prefix), but I may end up standing corrected.
I simply mentioned red & blue to cover both bases.
If memory serves me correctly, another forum member mentioned a few years ago that new Holden OEM dipstick tubes are NLA?
#7 S pack
  • 15,539 posts
Posted 09 July 2018 - 06:06 PM
Ok, I'll correct myself.
WB Blue 6 dipstick tube is different to the Red six tube but either tube should fit the Black 202. Just need the matching dipstick.
There are aftermarket tubes and dipsticks available but how good they are is another question.
#8 Ice
  • 15,123 posts
Posted 09 July 2018 - 08:39 PM
Unless you got both NOS ones ✌️
#9 D-Train
D-Train
  • 171 posts
  • Name:Dion
  • Car:LC SL
Posted 09 July 2018 - 09:08 PM
So you've got what I'm after ICE?
#10 Ice
  • 15,123 posts
Posted 09 July 2018 - 09:46 PM
Yes mate both new old stock tube and dipstick
#11 rodomo
  • 17,999 posts
Posted 09 July 2018 - 10:26 PM
^ ^ ^ ^ ^ ………………...clearly the forum dipstick guru :stirpot:
#12 Ice
  • 15,123 posts
Posted 09 July 2018 - 10:48 PM
Really
#13 D-Train
D-Train
  • 171 posts
  • Name:Dion
  • Car:LC SL
Posted 10 July 2018 - 05:56 PM
Love it. What the cost?
The motor is already together, I have t nad a look yet but is it easy to get out?
#14 S pack
  • 15,539 posts
Posted 10 July 2018 - 06:15 PM
To get the plug out of the dipstick hole? Best way is to punch it back up and out with a long drift or rod but that would require removing the sump.
Probably need to install a screw into the plug to pull it back out but that will require making a hole in the plug which usually means creating swarf which you don't want getting into the engine.
#15 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 10 July 2018 - 06:49 PM
This one Dave..remember 😁
Attached File  post-45764-0-17408000-1478993052.jpg   744.93K   4 downloads
#16 S pack
  • 15,539 posts
Posted 10 July 2018 - 07:02 PM
:spit:
#17 Ice
  • 15,123 posts
Posted 10 July 2018 - 07:39 PM
Love it. What the cost?The motor is already together, I have t nad a look yet but is it easy to get out?
Pm sent
#18 rodomo
  • 17,999 posts
Posted 10 July 2018 - 10:26 PM
You might be able to pin punch a hole in the plug, then screw a self taper in and extract it that way?
Pin punch would have to be really sharp, like a needle, as not to punch the plug into the sump. No swarf if it works?
