Booster delete
2 replies to this topic
#1 D-Train
D-Train
  • 171 posts
  • Name:Dion
  • Car:LC SL
Posted 12 July 2018 - 06:39 PM
Ok guys, I’ve decided to remove my booster for the time being. I removed the booster frame and it’s just a matter of bolting in the m/c. Question I have is what part do I need to connect to the lower hole on my brake pedal. The one on The top hole is too big to fit into the master cylinder bore or do I just need to make my own by sticking the booster one in a lathe and turning it down. A big thanks to dattoman. You’ve solved my second last problem holding up my build.
Attached File  F186E69E-C99C-4D50-9B5D-4927BCA81B41.jpeg   401.04K   2 downloads
M/c hole that was under the booster frame
Attached File  880D45EE-509D-472A-87F9-1667C4BA967D.jpeg   286.96K   0 downloads
My current m/c
Attached File  0C948722-FAAB-4C60-9DCF-0FC048EABD10.jpeg   276.26K   0 downloads
My new brake pedal, as the one fitted is for a manual. Also I now have a manual brake and clutch pedal if anyone needs one.
Attached File  983E48F8-74D6-483D-8913-D13F460F7912.jpeg   295.24K   0 downloads
Brake pedal as is, currently setup for a booster.
Thanks all for your help and efforts.
#2 Dr Terry
Dr Terry
  • 3,276 posts
Posted 13 July 2018 - 07:39 AM
You need the push rod & clevis from a drum braked car.
One from any early Holden may do the job, if is made the correct length.
Dr Terry
#3 gtrboyy
gtrboyy
  • 3,137 posts
Posted 14 July 2018 - 02:12 AM
I used Dellows adjustable pushrod & clevis...think it came from their hydraulic clutch kit.
Looks just like what drum braked cars had.
M/cyl bolts straight to firewall,use 2 shorter bolts & dellows pushrod...iirc carefully bent brake lines to fit but later on made shorter/neater lines to suit v8 conversion.
Brake pedal was harder obviously...worked well manual but not so well with automatic in gear at lights.
