Hi Guys; not quite a Torana question but as I’m always impressed with the Holden 6 knowledge (and passion) shown on this site I thought it was the only place to ask.
I’m after suggestions as to which needles (fixed, not sprung) I should initially start with in my triple HS6 SU carb / Speco GT-X manifold setup, (they are fitted with .100 “ jets).
The motor will be an X2 186 block bored to 60 thou running a black 3.25 inch counterbalanced crank, starfire rods, dished pistons, stage 3 Yella Terra head with roller rockers, extractors and HID ignition. Cam spec yet to be confirmed but will be a mild performance grind suitable for an elderly, classic street car.
I realize it will be a guessing game until I have the engine running and have dusted off my old carb balancer and Colourtune setup – I’ve been running injected motors for the last two decades and am looking forward to reliving the thrill of running multiple carbs, here’s hoping the old skills kick in!
My initial plan was to run 0A6 as recommended for the XU1 SU conversion but a little research suggests they tended towards running rich and the 0A5 would be a better choice?
Any advice will be much appreciated and I do realize we are talking ‘guesstimates’ here, all I’m looking for is a starting point.
