My lh povo pack resto has rust in the floor pan below pedal assembly and on the pass side in the same spot. Suggests plenum rust holes. Any idea how many hours to unpick and repair? I know it depeds on how bad, any shots in the dark?
Lh plenum repair
_74lh4me_
, Jul 23 2018 06:44 PM
5 replies to this topic
#1 _74lh4me_
Posted 23 July 2018 - 06:44 PM
Posted 23 July 2018 - 07:16 PM
Post up some pics if you can Phil.
#3 _74lh4me_
Posted 24 July 2018 - 03:23 PM
photos of floorpan front both sides
#4 _THE ZODIAC_
Posted 24 July 2018 - 11:11 PM
I would bank on 16hrs per side. 8 hours to remove and clean up areas to be welded and a day or 8 hours to weld in new pan grind / clean up welds.
no two obs worth.
#5 _74lh4me_
Posted 25 July 2018 - 07:46 AM
Thanks for the input, it helps me estimate build costs.
Posted 12 August 2018 - 11:08 PM
I unpicked mine and didnt take too long.
And cut the sides qith a grinder.
Was alot of surface rust underneath and wire brushed straight off.
I will be treating with kbs and re welding back on.
Pics are in my thread.
There is actually a vid on you tube for lx torana restoration and he shows the whole process
Worth a watch.
Good luck with it.
Sent from my SM-G930F using Tapatalk
Worth a watch.
Good luck with it.
