HQ Brake Conversion
Posted 27 July 2018 - 09:17 PM
Posted 28 July 2018 - 06:40 AM
I wouldn't bother unless you're planning on some Dukes of Hazzard manoeuvres while you have a handful of steering lock...
The caliper isn't hitting the cross member before the steering stop though is it?
Posted 28 July 2018 - 07:34 AM
....will it hit in the real world?
Possibly, theres still range of movement in all the rubber bushes that can't easily be replicated.
Posted 28 July 2018 - 02:08 PM
76lxhatch - No it isn't - the Photo shows Steering on Full Lock - Rack has bottomed out before Harrop Arms have touched Steering Stop on LCA.
Posted 28 July 2018 - 04:48 PM
Pretty sure l read about L34's having the top control arm notched in this area to clear
HQ calipers on full compression and full lock. I have the same set up as you and l did mine
as l found going down a steep hill we have around here called Arthur's seat which has really
tight switchback corners and when nose down hard on the brakes they were just touching.
Posted 29 July 2018 - 09:21 PM
I think you will that on full lock the tyre will hit the guard before the suspension hits the bump stop.
