BA or VT brake caliper
8 replies to this topic
#1 jef
jef
  • 35 posts
  • Car:LH SL
Posted 06 August 2018 - 01:11 PM
Hi i have upc hubs, vt rotors with 4 pot nissan calipers but they have shit clearance , thinking of changing to Ba falcon or vt calipers  and want them on the front so can still have full lock with steering.
#2 caterham2
caterham2
  • 348 posts
  • Location:Mansfield North East Victoria not the other one in QLD
  • Car:Ford Focus RS AWD Gone over to the dark side .. Mercedes-Benz SLK350 Ford Cortina 2 door MK1 Twin Cam
Posted 06 August 2018 - 02:26 PM
At the risk of starting a shitfight, having owned a number of Falcons and driven a number of Commodes, Ford has always had the better brakes.
#3 limo
limo
  • 2,672 posts
Posted 06 August 2018 - 04:35 PM
I thought there is difference on the way the caliper bolts to stub axel
Ford have thread in caliper
Commodore thread in stub
so depends what you have now as to which fits easier
#4 Cook
Cook
  • 1,504 posts
Posted 06 August 2018 - 06:04 PM
I might be completely off the mark here but with the Hoppers kit, which I'm pretty sure are AU calipers, you have to swap the stub axles left to right to retain clearance on full lock, which puts them on the back of the rotor.  Cheers Ron
#5 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 06 August 2018 - 06:38 PM
Yes, there are plenty of threads on here about these kits.
https://www.google.c.../forums upc kit
#6 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 06 August 2018 - 06:44 PM
Mine is UPC Hubs, VT Discs, Harrop Arms, Nissan R32 4 spots, but with custom caliper mounting bracket, and I mucked about raising the upper arm, after that i discovered you can get longer ball joints, this would make it an easier bolt together.
#7 jef
jef
  • 35 posts
  • Car:LH SL
Posted 06 August 2018 - 09:11 PM
that's a fancy bracket, what size rim can you still fit. did you use the 1'' or .5'' ball joint and did it make a big difference for clearance with the UCA raised.
#8 rodomo
  • 17,999 posts
Posted 06 August 2018 - 11:35 PM
Wash your mouth out! :<_<:
#9 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 07 August 2018 - 07:44 AM
Neither, I put all of that together before I found out about the longer ball joints, but, if I have to revisit it I'll put a set in then.
At a guess the 1" would be easy, the 1/2" not so sure, I put the ball joint in from below and added a shim of about 1/8" between the upper arm and ball joint.
Wheels are 15x7 with something like a 3" back space, but I'd have to measure them to be certain, there is a nice amount of clearance for everything.
I can get a better pic if you want, and I could measure the BS of the wheels to be more certain.
