Is there a difference between an lc horn ring and a lj horn ring??? Or are they interchangeable?
Lc and lj horn ring
evl666
, Aug 19 2018 10:23 PM
3 replies to this topic
Posted 19 August 2018 - 10:23 PM
Posted 20 August 2018 - 04:05 AM
Dunno,but some horn rings cancel the indicator signal
In some models earlier and later because of the
different ratios in steering rack and where the bumps
are located on the horn ring?
im sure lc and lj are same ratio and fit each other.
But im only guessing.if i had a steering puller id
take my wheel off and compare to the lj.
Edited by madtoranajzedded, 20 August 2018 - 04:07 AM.
Posted 20 August 2018 - 07:33 AM
I believe that the LC & LJ are different in that area.
LC uses the HK/T/G blinker mechanism while the LJ uses the HQ.
Dr Terry
Posted 20 August 2018 - 04:37 PM
So going by that lc's indicator cancelation bumps
would b in different location,going by different rack
i think if i remember correctly lc's have pointy bumps
on an angle and ljs are rounded?.
Should still bolt up though hey..
Edited by madtoranajzedded, 20 August 2018 - 04:38 PM.
