Inner Fender Panels
16 replies to this topic
#1 _Housecat1977_
_Housecat1977_
Posted 21 August 2018 - 08:52 PM
Hi,
Was wondering if someone could show me pics of where on the LC/LJ these parts go. In my misguided youth, I threw some of these away thinking they did nothing. Later reflection is, they probably do something.
Holden Inner Fender Front Panel LC LJ Left Hand
Attached File  2807265.jpg   3.56K   5 downloads
Holden Fender Sect Lhf Inner Rear Panel Set LC LJ
Attached File  h1242.jpg   5.79K   3 downloads
Paul
#2 rodomo
  • 17,999 posts
Posted 21 August 2018 - 09:09 PM
The smaller ones (top pic) go up near the headlights. The bigger ones go rear of the tyre/wheel.
#3 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 21 August 2018 - 09:30 PM
Stops mud and dirt getting into the front guard.
#4 rodomo
  • 17,999 posts
Posted 21 August 2018 - 09:43 PM
Debatable, I'm deleting mine.
#5 _Housecat1977_
_Housecat1977_
Posted 21 August 2018 - 10:06 PM
Thanks for that guys, I just couldn’t picture where the smaller one went.
I am all for keeping dirt out of places. But I can’t help but wonder what purpose the GTR flutes serve if they are blocked off by the inner liner or, are they removed on the GTR’s?
#6 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 21 August 2018 - 10:10 PM
GTRs have them fitted ,LC- LJ all have them ,I'd be fitting them as intended imo.Flutes just for looks I reckon.
Edited by Indy Orange, 21 August 2018 - 10:11 PM.
#7 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 22 August 2018 - 07:36 PM
The flutes are just for aesthetic purposes basically.
#8 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 22 August 2018 - 08:05 PM
Just like the Monaro flutes ,they do look good!
#9 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 22 August 2018 - 08:25 PM
Yeah they look the goods mate, especially in the monaro's
#10 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 05 March 2020 - 01:50 AM
Can we purchase the rubbers anywhere that are stapled
to the front inner fender plate..
#11 Maximart2
Maximart2
  • 18 posts
  • Name:Martin
  • Car:LC GTR
Posted 05 March 2020 - 08:04 AM
I have thought a lot about whether the guard flutes are functional or not and I have a theory! It goes a bit like this.
In order to suck air into your mouth you get a faster air flow if you close your mouth into a small hole, think sucking milk through a straw. In Toranas you have a small round hole behind the water deflector (Usually attached to the bonnet hinge) at the back of the engine bay that leads from there into the space inside the guard that the flutes lead to. So if the inner rear panel (Splash panel) is fitted and its seal is ok how does it all work? As you drive, air rushing past the guard flutes create a vacuum inside the guard causing hot air inside the engine bay to be sucked through the small hole at the back corner of the engine bay into the inner guard and out through the flutes. I reckon this could be tested by creating smoke in the engine bay and driving down the road and seeing if it does indeed get sucked out the flutes. What do you al think?
#12 _RS250_
_RS250_
Posted 05 March 2020 - 09:43 AM
My 2 cents,
I thought I once heard about 30 years ago from Harry or someone that the XU1 front spoiler is to help deflect air toward the front brakes, then removing the splash guard panel helps the air exit through the flutes.
Not an exact science but any little bit helped under racing conditions. Harry would always tell his drivers not to use the brakes.
Most common people removed the splash guard because of the build up of dirt and grit behind it that helped promote rust in the lower front guard and almost never put back after a rust repair.
#13 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
Posted 05 March 2020 - 10:53 AM
Flutes do nothing at all.just for looks.
The hole behind drip rails is spose to b
a jig hole or alignment hole during assembly..
Pretty sure someone started a thread on this awhile back.
#14 lx308
lx308
  • 2,838 posts
  • Name:Tony
  • Car:Nuffin. Goin touring.
Posted 05 March 2020 - 11:41 AM
I'm sure Marty posted somewhere in here http://www.gmh-toran...e-marty-report/ about that rubber. Just gotta find it.
#15 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
Posted 05 March 2020 - 03:43 PM
Thanks Tony..i knew there was something on here about
It.
Like searching for a needle in a haystack lol..
#16 S pack
  • 15,539 posts
Posted 05 March 2020 - 07:20 PM
Maz, I think Marty used a rubber extrusion like this from Clark Rubber.
This one is classed as 7mm https://www.clarkrub...sion-22mm-x-7mm
This one is 14mm https://www.clarkrub...nel-29mm-x-14mm
#17 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
Posted 05 March 2020 - 08:31 PM
Oh thank the lord jesus 😂😂😂 just went through
martys thread up to page 41.only flicking through it
looking for a pic..man that took awhile.all im seeing is whitee lines lmao..
Thanks Dave ..your a champion 👍
