Trimatic kickdown
Posted 23 August 2018 - 08:39 PM
Posted 23 August 2018 - 09:36 PM
I suppose anything's possible but I think it'd be easier to swap the whole trans for a later version.
The case and the valve body would be different at the very least.
Posted 23 August 2018 - 10:03 PM
Is the vacuum enough for kickdown or is manualising it my only option if I don't use the kickdown cable?
Posted 24 August 2018 - 05:34 AM
I think the vacuum to the modulator more controls the timing of up-shifts, as in how much load is on the engine and how long it should hang in a gear.
I remember a mate driving 30-odd kms home one night in 2nd because the vacuum line fell off the modulator and the transmission (a Trimatic) absolutely refused to select third gear.
Posted 24 August 2018 - 06:04 AM
Posted 24 August 2018 - 06:59 AM
Cheers. I'm just struggling for room. I've got a Vo efi 202 in my LC. My supercharger piping runs over the top of the rocker cover and leaves enough room for the throttle but the kickdown cable which I think goes above will not make it cos the pipes in the way. I'll see if I can do anything else.
Is the vacuum enough for kickdown or is manualising it my only option if I don't use the kickdown cable.
Assuming you are running a throttle cable to the EFI throttle body?
Posted 24 August 2018 - 09:15 PM
And yeah a throttle cable, using a vk bracket bolted to the rocket cover
Posted 24 August 2018 - 10:10 PM
Is it possible to put the kickdown cable inside another sheath to protect it or perhaps wrap it with some of that heatproof stuff they wrap extractors with?
Posted 24 August 2018 - 10:13 PM
Posted 27 August 2018 - 01:47 PM
don't know if it would work but could you use a solenoid to pull the cable ? , something like a old boot release from a commodore
and wire it to a pedal switch
Posted 27 August 2018 - 02:44 PM
Is the kickdown lever either on or off or is there stages?
Now how will the vacuum side of the tri attic work with my supercharger. I'm guessing I'll having little to no vacuum so is it redundant?
Posted 27 August 2018 - 07:33 PM
Some info here about the trimatic cable and electric kick down. http://holdenpaedia....imatic_Kickdown
Why not use the accelerator pedal assy with electric kick down switch from an LJ Torana that was factory auto?
Edited by S pack, 27 August 2018 - 07:34 PM.
Posted 28 August 2018 - 06:07 AM
Most modulators you can buy these days are adjustable which gives you a bit of wiggle room with the vacuum. You definitely want this working.
Posted 29 August 2018 - 11:39 AM
