Aussie 4 Speed Jamming In Reverse
3 replies to this topic
#1 71Ranger
71Ranger
  • 267 posts
  • Name:Brian
  • Car:71 LC
Posted 13 September 2018 - 01:25 PM
Hi,
After a little help. My Aussie 4 Speed is jamming in reverse and a little hard to cross the gate to select second.
Firstly, suggestions on the probable cause and the rectification.
Secondly, can someone recommend a reputable manual gearbox mob - Im a Melbourne.
Many thanks
Brian
#2 limo
limo
  • 2,672 posts
Posted 13 September 2018 - 05:09 PM
I would suggest worn linkages or wear in shifter if you have used car for a while and nothing been done to gearbox / shifter
recently.
grooves wear in the connecting areas and put adjustment out.
rods and holes
#3 liswar2
liswar2
  • 1,481 posts
  • Name:Wazza
Posted 17 September 2018 - 09:09 AM
For reverse gear getting stuck, check the adjuster nut has not come loose and moved forward, this is why there should be to 2 nuts on the end , 1 for correct adjustment and 1 to lock it in place,
I have had this happen to me before, a easy fix...
Hopefully this solves 1 issue.
Wazza
#4 gtrboyy
gtrboyy
  • 3,136 posts
Posted 17 September 2018 - 03:40 PM
Agree with limo if it's got an old shifter or sloppy linkages it was common for them to bind eventually jamming in gears 1st & reverse untill you got under there to pry them apart.
Check adjustment of linkages or renew.
