Auto Brake Pedal sleeve Fitment
2 replies to this topic
#1 Cook
Cook
  • 1,505 posts
Posted 19 September 2018 - 12:07 PM
Hi all, Just wondering if this sleeve should be a tight fit or is it ok if it moves around.  I've just cleaned this up, replaced the bushes and now not as tight as original.  If it's meant to be tight any suggestions on what to use (tape etc) to tighten the sleeve against the bushes.  As always thanks in advance.  Cheers Ron
#2 S pack
  • 15,539 posts
Posted 19 September 2018 - 09:20 PM
I believe it is a spacer or anti crush tube. I am guessing that when you install the pedal and tighten the pivot shaft/bolt & nut the spacer will be immobilised and the pedal bushes will pivot on the spacer.
Edited by S pack, 19 September 2018 - 09:22 PM.
#3 Cook
Cook
  • 1,505 posts
Posted 19 September 2018 - 09:27 PM
Thanks Dave.  I just wasn't sure if it needed to be tight and move with the pedal or not so tight and be able to move independently. I think there is another spacer that goes on the bolt as well which may hold it in place but I haven't got that far yet. Might sound stupid but I pulled it apart some years ago and can't remember. I have another pedal from a WB and you would need to almost press out the sleeve.  Cheers Ron
