Courtesy light wiring entry point.
3 replies to this topic
#1 Indy Orange
Indy Orange
  • 2,840 posts
  • Name:Paul
Posted 01 October 2018 - 02:22 PM
Hi all I'm wanting to know which hole is used for the wiring for interior light ,does in come in through the elongated hole ,thanks Paul.
#2 jd lj
jd lj
  • 2,099 posts
  • Name:James D
  • Car:LJ SVO
Posted 01 October 2018 - 06:23 PM
While we're talking about the courtesy lights wiring, behind where the radio goes there's two wiring harness tabs attached to the interior side of the plenum, I assume that the white wire going to the passenger side courtesy light switch is meant to run through these. Is this correct? Are there any other wires that should go through these tabs?
#3 S pack
  • 15,522 posts
Posted 01 October 2018 - 06:57 PM
From memory the wiring comes out the top of the 'A' pillar and continues across behind the support panel to the dome light.
I can remember seeing the orange and white wires with the sun visor bracket removed once upon a time.
Edited by S pack, 01 October 2018 - 06:57 PM.
#4 Indy Orange
Indy Orange
  • 2,840 posts
  • Name:Paul
Posted 01 October 2018 - 07:04 PM
Thanks Dave!
