Pulling apart an engine off gumtree, with what looked like a spun No.3 main bearing.
Found a welsh plug blocking off the relief valve in the oil pump, I'm thinking this needs to go ...
20181002_125216.jpg 278.36K 19 downloads
Posted 02 October 2018 - 03:13 PM
Posted 02 October 2018 - 05:02 PM
This is one of the best info sources I have read on Holden oil pumps, Have a read. The original photos are reposted on page 7.
https://www.aussiev8...rmance-use.html
Edited by CI 0308, 02 October 2018 - 05:05 PM.
Posted 02 October 2018 - 07:05 PM
Posted 02 October 2018 - 11:24 PM
Posted 03 October 2018 - 11:42 AM
I understand about blocking the bypass, but I've shown someone blocking the relief valve, it still had the bypass valve. That thread by TK383 is brilliant but it didn't discuss blocking off the relief valve.
Posted 05 October 2018 - 10:49 PM
Edited by ozyozyozy, 05 October 2018 - 10:50 PM.
Posted 06 October 2018 - 03:48 PM
No probs, I had to double check myself.
Posted 14 October 2018 - 09:37 AM
As a follow up the other thread doesn't cover in a lot of detail rerouting the relief valve.
The relief valve regulates pressure, so that during operation it will likely be partially open. That's a problem because it allows unfiltered oil to bypass the filter. The welsh plug that was originally put in mine sent all the unfiltered oil directly past the filter, this mod forces it all through the filter.
I through tapped that hole and put a grub screw at the bottom as recommended, others use M12 x 1.0 or 1/2 UNC. I used 1/4 NPT which is tapered such that the grub screw can't work out of the bottom and block the outlet. Used locktite anyway.
20181011_215742.jpg 196.5K 16 downloads
I figure that the grub screw semi-blocks the relief valve piston on the pressure side which should increase oil pressure, so I didn't bother shimming the spring like others.
20181013_123027.jpg 187.27K 17 downloads
Also the thread suggests a 21 mm welsh plug, mine was off a late 1990s cast steel oil pump housing, that needs a 20 mm plug. Used a small amount of sealant around the lip to be sure.
20181013_122024.jpg 119.81K 16 downloads
Posted 23 May 2019 - 02:59 AM
Sorry to bring up an old thread, just to be clear after the hole was tapped through, a grub screw was put in and screwed all the way to the bottom? I assume the spring would push up against therefore no need to shim the spring?
Posted 23 May 2019 - 10:52 PM
Yes to the bottom of the hole, but not so far as to block the passage from the centre of the oil filter if you know what I mean.
The spring is in the section to the side, and shimmed to increase preload and pressure to open / reduce pump pressure. You probably could shim it, or use a tapped thread and bolt behind it as suggested by TK383 to change preload. I didn't shim it because I've partially blocked the passage that pushes the spring back, which might have the same effect.
Posted 29 May 2019 - 03:53 AM
So as long as i shim the spring I dont need to worry about tapping and inserting a grub screw?
Posted 31 May 2019 - 08:07 AM
Well I didn't shim the spring because the grub screw I used partially blocks that passage. But technically they do different things.
Shimming the spring increases its preload and makes it harder to open that relief passage so increases the pump oil pressure level.
Tapping and inserting a grub screw as shown above is more about ensuring oil can't return to the engine without going through the filter first.
