Rocker ratio on Holden 6
#1 _202 Corona_
Posted 12 October 2018 - 11:26 AM
1. Will changing the ratio of my rocker arm affect clearance/valve train geometry. (it is a strip only motor)
2. What ratios has anyone else ran before?
Posted 12 October 2018 - 06:12 PM
So I currently run a cam with 240 deg. Duration and 400 thou lift at the cam using 1.5:1 rocker arms. I sent away for cam recommendations now that it has triple Webers on it. The cams are all very similar in most aspects to mine, the major difference is more lift, which brings me to my questions,
.400" lift at the cam or at the valve?
Posted 13 October 2018 - 05:31 AM
I run SBC 1.6 rockers on my inlets 1.5 on the exhaust.
Cam has .540" lift with a 1.6 rocker, 262 deg duration and 105 deg LSA. Static comp is 11.6.
My head has .100" off it and the slugs are .010" above the deck everything clears with that lift.
#4 _202 Corona_
Posted 13 October 2018 - 08:25 AM
The motor had 11.8:1 compression before we touched it and was running AVGAS, so we will take it back to there.
My flat tops sit flush with the deck.
After seeing the head disassembled we are a little amazed it ran an good as it did!
Should be easy power there.
Posted 13 October 2018 - 09:09 AM
I agree with Adam, change the cam. .400" lift at the valve is only going to increase to .425" with 1.6:1 rockers or .438" with 1.65:1 rockers.
#6 _202 Corona_
Posted 13 October 2018 - 09:41 AM
Posted 13 October 2018 - 04:37 PM
You need to pick your cam based on the head flow specs. If the head flow peaks at .420 lift then the cam you have may be fine... but if you head flow peaks at .550 you should run a cam with more lift so that you match cam/ rocker lift with the peak flow with the head.
As others have said, if its a strip only car, irrespective of lift, your cam is pretty mild for a race only setup. Good drag racing cams are usually around 254-260@50 thou on about 106-107 LSA. The lift you should just match with the head. Some heads roll over at .450 lift so no point running much more than that if the head rolls over.
#8 _202 Corona_
Posted 14 October 2018 - 12:10 PM
But yes thanks for pointing out what should have been obvious to me, will wait and see what the head ends up with.
#9 _202 Corona_
Posted 02 December 2018 - 07:01 AM
Posted 02 December 2018 - 07:24 AM
Shiiiiiiiiiii neeeeeeeee
Posted 03 December 2018 - 02:45 AM
