Clutch linkages (rat trap) breakages
19 replies to this topic
#1 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 15 October 2018 - 07:48 PM
The clutch linkages on my LJ XU1 were replaced in the early 80's with NOS. I know the previous owner (mate) had drama with the original factory linkages and bought quite a few NOS linkage parts from our local Holden dealer which I was told from Holden were a modified part (modified version of the original) and they came with the car when I bought it this year.What I want to know is what actually breaks when these linkages fail? The only part that I can see that would most likely fail is the wire rod from the pedal inside cab which exits into engine bay.
#2 S pack
  • 15,538 posts
Posted 15 October 2018 - 08:21 PM
Yep the only clutch linkage part that has ever suddenly failed on mine is the pull rod from the pedal to the relay lever.
Sure the other parts wear and can eventually fail.
BTW, part of your mechanism is from a HK, T, G Holden.
#3 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 15 October 2018 - 08:39 PM
Worst piece of shit design that gm ever came up with !
#4 S pack
  • 15,538 posts
Posted 15 October 2018 - 09:13 PM
lol, a cable operated clutch would have been too simple for the then GMH engineers to design but Vauxhall could do it. :spit:
Edited by S pack, 15 October 2018 - 09:15 PM.
#5 goxu1
goxu1
  • 690 posts
  • Name:Paul
  • Car:4/73 Cyan Metallic GTR XU-1
Posted 15 October 2018 - 09:17 PM
Is there anyone recoing these ?
#6 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 16 October 2018 - 06:40 PM
The rat trap started in 67 camaro roughly Dave, didn't work in it, but holden thought they'd borrow the piece of shit & see if it was as bad from 69 - 80 & it was !
#7 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 16 October 2018 - 06:42 PM
Looking at possibly doing these after Christmas mate, but way to busy before then. I've got some idea's on modifying 1 for a trial too. No idea on price until we have to time to look into them. Gary.
#8 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 16 October 2018 - 07:07 PM
Thinking if the only item failing in the rat trap system is the thin rod from the pedal and the remainder work ok (other than normal wear and tear), then mabey manufacture a stronger rod?
#9 gtrboyy
gtrboyy
  • 3,137 posts
Posted 17 October 2018 - 12:46 PM
Yep snapping ball off clutch pull rod was common especially with heavier pressure plate for hipo 6cyl that needed it.
Had to have a spare as never knew when it would eventually break as new replacents seemed weaker.
Other than that pivot points will grind down or holes elongate from decades of use...weld em' up & file/grind untill new again.
#10 Ozchuck
Ozchuck
  • 45 posts
  • Name:Chuck
  • Car:Not enough !!
Posted 17 October 2018 - 10:17 PM
I've also snapped a couple of clutch pedals using HD pressure plates. I absolutely despise the rat traps as they fail at the most inconvenient times....  :angry:
#11 dascind
dascind
  • 216 posts
  • Car:71 LC GTR
Posted 26 October 2018 - 09:48 AM
I had the anchor strap break - this is the part that slips over the pedal way up under the dash and the same part has the cable connected to the end of it going the fire wall.
Lucky it happened close to home (thankfully car was with NRMA for short tow) BUT even more thankfully I was not in heavy traffic and could glide to the edge of the road. The round anchor part on the actual clutch pedal had worn into a groove and the anchor part (see pic) had just grooved itself in with no free play. The anchor part is held on by a small clip - think Rares have them.
As outlined above - a terrible set up.
#12 jpxu1
jpxu1
  • 549 posts
Posted 28 October 2018 - 12:15 AM
Yep, horrible design, cheap and nasty engineering.
All the pivot points would wear and chop out due to poor design and lack of lubrication.
I used to repair and replace frequently back in the day (learnt to change gears without the clutch too), but eventually decided to get a new set of linkages all hard chromed to see if that would help.
Never touched them again, and I drove my poor old Torrie for 500k miles.
JPXU1
#13 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 28 October 2018 - 02:00 AM
Do i see pink crayon on that rat trap
#14 lx308
lx308
  • 2,838 posts
  • Name:Tony
  • Car:2005 CV8 Monaro
Posted 28 October 2018 - 08:34 AM
Might be genuine Holden secret service crayon Maz. Very rare
#15 Strat
Strat
  • 88 posts
  • Name:Nick
  • Car:LJ Torana
Posted 12 April 2022 - 07:58 PM
Hi Gary, this is a long shot, but did you end up making any rat traps ? Do you have any for sale or do you know anyone that sells them complete ? Thanks Nick
#16 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 13 April 2022 - 09:24 PM
No sorry mate, i canned the idea for the time & just repaired the 1 in the lc back to standard. Weld file sand ect ect.
#17 Strat
Strat
  • 88 posts
  • Name:Nick
  • Car:LJ Torana
Posted 13 April 2022 - 10:34 PM
Thank you
#18 claysummers
claysummers
  • 3,329 posts
  • Name:Clay
Posted 13 April 2022 - 10:39 PM
LC hydraulic set-up currently on gumtree $400.
#19 claysummers
claysummers
  • 3,329 posts
  • Name:Clay
Posted 13 April 2022 - 10:50 PM
Correction, $140, not $400
Holden Torana LC LJ Dellow hydraulic clutch conversion kit on Gumtree http://www.gumtree.c...&utm_source=sms
#20 Strat
Strat
  • 88 posts
  • Name:Nick
  • Car:LJ Torana
Posted 14 April 2022 - 07:28 AM
Thank you Clay .Trying to keep it as original as possible.
