Correct LCGTR fan
Posted 20 October 2018 - 07:43 PM
Posted 20 October 2018 - 08:23 PM
Posted 20 October 2018 - 08:35 PM
Posted 20 October 2018 - 08:54 PM
Rob,it's a good original pump with the cast impeller so I want to use it rather than one of those tin ones.Probably wasting your time on old pumps? A press would be better.
Posted 20 October 2018 - 09:24 PM
Posted 20 October 2018 - 10:49 PM
Posted 21 October 2018 - 11:58 AM
#8 _LC870_
Posted 21 October 2018 - 02:19 PM
I think that the 69 LC GTR had the small hub .
Regards LC870
Posted 21 October 2018 - 03:28 PM
Hi Guys.
Many parts catalogues don�t list these pumps properly.
There are actually 4 different water pumps for the Holden 6.
1. EH to HK (small hub & short shaft) this has the common industry part no. of W587
2. HT to HZ/VB & LC to UC Without viscous fan clutch (large hub & short shaft) part no. W726
3. HJ to HZ/VB & LC to UC With viscous fan clutch (large hub & long shaft) part no. W814
4. WB/VC to VK Large housing & bearing (commonly called the 'Jumbo' pump) part no. W815
Type 1 has a unique (smaller) bolt pattern, so must be used if you want to retain the original pulley and fan.
Types 2 & 3 use the same pulley (as each other) and can often be interchanged; the only difference between the 2 is the length of the shaft in front of the flange. Type 3 is usually the one seen on cars with factory-fitted Frigidaire air conditioning.
Type 4 has the same hub as 2 & 3 but is further forward so its pulley has a bigger offset. Type 4 was actually introduced after the Blue motor intro, so early WB/VC Blue motors can be seen with the type 3 pump.
Hope this helps. Can we make this sticky, it comes up alot ?
Dr Terry.
Posted 21 October 2018 - 03:30 PM
Posted 21 October 2018 - 04:19 PM
Posted 21 October 2018 - 05:40 PM
Hi Paul...I'm no expert....but here is the old and new on my 12/70 GTR
Posted 21 October 2018 - 05:47 PM
Posted 21 October 2018 - 06:19 PM
Posted 21 October 2018 - 07:18 PM
Posted 21 October 2018 - 07:48 PM
Posted 21 October 2018 - 09:08 PM
Posted 21 October 2018 - 10:16 PM
Posted 22 October 2018 - 06:51 AM
The LC & LJ parts catalogues all list the same Pulley for LC & LJ 6cyl.
Pulley for the HK 161 & 186 has a different part number.
LC GTR 2600S & 2850S are listed as having the same fan blade assy which is the same part number for LJ GTR.
Posted 22 October 2018 - 04:50 PM
Then that cant be the original fan then,it is for the small smaller hub,pulley.
#21
Posted 22 October 2018 - 05:43 PM
geez..I'm confused..your GTR setup is the
-small flanged pump,
-the small pulley
-and that fan
seems like a matching set to me?..or am I confused even more than I think?
The only thing wrong is the unpainted pump in your pic?...you can get a new correct one with the small flange, at Repco .
#22
Posted 22 October 2018 - 06:24 PM
LC & LJ GTR engine fan Pt No. 2810488
Pic courtesy of Forum member Daniel.
#23
Posted 22 October 2018 - 06:28 PM
Edited by Indy Orange, 22 October 2018 - 06:29 PM.
