Gaps LC LJ
15 replies to this topic
#1 LC69GTR
LC69GTR
  • 2,760 posts
Posted 22 October 2018 - 04:07 PM
Is there a difference in LC and LJ Doors or guards?
Most cars seem to be like bottom photo but i have also seen some like top photo more gap where arrow is
Car below has it to
Thanks in advance
Edited by LC69GTR, 22 October 2018 - 04:11 PM.
#2 jd lj
jd lj
  • 2,100 posts
  • Name:James D
  • Car:LJ SVO
Posted 22 October 2018 - 04:49 PM
I think that how the gaps turned out was just up to luck on the day of manufacturing.
My door gaps are like the top picture but much more noticeably on the passenger side, the drivers side fits better. This is with all original panels to the best of my knowledge.
#3 S pack
  • 15,538 posts
Posted 22 October 2018 - 06:15 PM
Good old 1970's Aussie manufacturing. :spoton:
#4 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 22 October 2018 - 06:57 PM
Well the gap on the top one has been sikaflexed, so the guards have probably been of ect, if your guards are original & the same from side to side, then leave them exactly how they are, as Dave said 70's manufacturing. If that's how it was, that's how you keep it. I would, a restoration is taking something back to how it was, i personally think they look correct being a little bit factory rough around the edges myself. Gary.
#5 Ice
  • 15,119 posts
Posted 22 October 2018 - 09:05 PM
Friday build 3.30 pm ✌️
#6 S pack
  • 15,538 posts
Posted 22 October 2018 - 09:09 PM
My brother had an early build LC 82311, it was body #25B or 29B, can't quite remember which now.
The joint where the top of the guard meets the cowl was lead wiped on both guards and the guards were the originals.
#7 rodomo
  • 17,997 posts
Posted 22 October 2018 - 09:10 PM
But...………….was there a difference between LC and LJ doors is the question?
Also, Adelaide and Brisbane build?
Should have took a pic before I started but this is mine in the same area with about 3mm of build.
The door is not original to the car.
Edited by rodomo, 22 October 2018 - 09:17 PM.
#8 S pack
  • 15,538 posts
Posted 22 October 2018 - 09:13 PM
Yes, there is a difference between LC & LJ doors.
LJ has a cutout in the inner door panel for an ashtray mounted in the door trim, the LC doesn't.
#9 rodomo
  • 17,997 posts
Posted 22 October 2018 - 09:20 PM
Er duh :fool:
#10 Rockoz
Rockoz
  • 3,961 posts
  • Name:Rob
Posted 23 October 2018 - 07:41 AM
Didnt think lead wiping would work in that area.
Lead has little strength.
There is some flex in the area between the guard and the cowl.
I did some basic custom type stuff in the area back in the day, filling the gap.
It cracked the bog work first drive out.
Even tried hairy bog and it cracked that.
Brazed it. Cracked that too.
Eventually got a MIG and welded it up.
That went well.
But took it off the road soon after and cut the weld back out for another direction in what I was doing
#11 rodomo
  • 17,997 posts
Posted 23 October 2018 - 09:56 AM
Pic of mine prior to work (thanks to Sherlock)
#12 Indy Orange
Indy Orange
  • 2,846 posts
  • Name:Paul
Posted 23 October 2018 - 06:40 PM
Must vary a bit, here's mine.
Edited by Indy Orange, 23 October 2018 - 06:48 PM.
#13 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 23 October 2018 - 08:36 PM
Brissy car Paul ?
#14 Indy Orange
Indy Orange
  • 2,846 posts
  • Name:Paul
Posted 23 October 2018 - 08:56 PM
Adelaide Gary.
#15 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 23 October 2018 - 10:19 PM
Oh okay mate, thank you.
#16 LC69GTR
LC69GTR
  • 2,760 posts
Posted 30 October 2018 - 04:07 PM
Thanks for your input crew
