Lx 253 Trimatic to 4 speed
2 replies to this topic
#1 _Ptock_
_Ptock_
Posted 27 October 2018 - 12:10 PM
Hi Im thinking of converting my traumatic 253 to a four speed and after advise on what ill need
I already have manual pedals and the car was originally a sunbird with a 4 speed
thanks
#2 rodomo
  • 17,997 posts
Posted 27 October 2018 - 11:27 PM
There has been quite a few posts about this topic over the years: https://www.google.c...iw=1219&bih=842
#3 kodulh
kodulh
  • 47 posts
  • Name:Anu
  • Car:LH Torana
Posted 29 October 2018 - 08:26 PM
make sure you use HZ style cable padal assy and UC clutch cable.  [UC cable is apx 8 mm long. but you can use a 4 x  3mm washers and  adjest the cable] also use HM  L34 style headders if you can,  they will clear the clutch cable more than any extractors in the market. they are bit longer and pass the gearbox  X member.
hope this helps
