sumps
10 replies to this topic
#1 lawn bowls
lawn bowls
  • 262 posts
  • Car:72 lj 4 door
Posted 29 October 2018 - 01:43 AM
do high energy make sumps for 6 cylinder lj torana.
#2 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 29 October 2018 - 05:53 PM
They used to, someone else does i think its asr ?
#3 _LXT333_
_LXT333_
Posted 29 October 2018 - 07:16 PM
Slightly off Original topic
Anyone ever straightened a sump?
Just bough an Aeroflow 308 sump and it’s rocks around on the block quite a bit
#4 I'm a Red Motor fiend
  • 758 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 30 October 2018 - 05:56 AM
Torque it down without a gasket and you will find it will probably pull down flush.
#5 76lxhatch
  • 7,152 posts
Posted 30 October 2018 - 06:22 AM
Just make sure its not rocking around on the crank/rods first! Some of the internal windage trays are poorly fitted and bow up toward the crank, they need to be persuaded back the other way.
#6 _LXT333_
_LXT333_
Posted 30 October 2018 - 08:02 PM
Thanks guys.
Didn’t think about the windage tray but it’s definately rocking as if twisted.
I will double check nothing is touching.
Was up the shed bolting it down without a gasket.
I’ll undo em later and see if it has straightened out.
Thought about torquing em down with a wedge or block under opposing sides and twisting is back the correct way.
Have ordered one of those one piece rubber gaskets with the steel insert.
Believe it helps from overtightening so likely better on twisted sumps so doesn’t overtighten and squish the gasket out.
#7 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 30 October 2018 - 09:23 PM
You could use internal shake proof washers, so you don't have to really tighten it so much. Much better idea.
#8 I'm a Red Motor fiend
  • 758 posts
  • Name:Adam
Posted 31 October 2018 - 05:51 AM
I doubt it will have straightened out when you undo it. But given it will pull in as you have tested, when you put a gasket in and fasten it back down I would say it will be OK. I had one that rocked too but never leaked when in service.
#9 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 02 November 2018 - 11:31 PM
Should b plenty of good fabricators that could knock one up to suit your needs modifying your original sump.bigger capacity .baffled with more gates.
#10 _202 Corona_
_202 Corona_
Posted 23 January 2019 - 08:22 PM
Got this one made up years ago,was comparable in price to a bought one
#11 rodomo
  • 17,998 posts
Posted 23 January 2019 - 10:42 PM
I have a theory :ph34r:
