Can Floating Hubs be Reused BW78
2 replies to this topic
#1 davea79
davea79
  • 178 posts
  • Name:David Angel
  • Car:Never Mind
Posted 02 November 2018 - 08:29 PM
Gents,
I've got a BW78 out of an Auscar with:
-Full Floating Hubs
-Harrop Centre
-1570mm Width
I would like to repurpose this diff into a VH same length as 10bolt Salisbury= 1495mm.ish
Can go up to 1510mm as per baby Salisbury diff length.
Any issues you know of with safety removing old floating hubs that are fixed to tubes??
I am in Adelaide so if this is no problem, any recommendations on who to use that wont charge a mil?
#2 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,525 posts
  • Name:MAZ
  • Car:72 LJ SL SEDAN. 69 LC S 2 DR SEDAN
Posted 02 November 2018 - 11:54 PM
You will most likely need another spindle or maybe it can b cut off housing and lathed down and rewelded back on.id contact a qualified chassis shop to do it.. someone like frank zagari in S.A and he will tell you pretty quicky whats gotta b done..Frank and his crew are are up there with the best in the land in any fabrication work needed done..
#3 davea79
davea79
  • 178 posts
  • Name:David Angel
  • Car:Never Mind
Posted 26 November 2018 - 08:17 PM
Thanks for that. I call up a few shops & they agree as long as you can see the weld points, which you can. Purely labour they tell me.... the expensive part ;)
