Sold my torana, found something bigger
5 replies to this topic
#1 shanegtr
shanegtr
  • 533 posts
  • Name:Shane
  • Car:LJ 2 door
Posted 03 November 2018 - 12:00 PM
As the title suggests, I sold my LJ. I'd been thinking about getting something bigger as with 4 kids the torrie wasn't a very family friendly choice to go for a cruise. So I started thinking about something bigger to replace it with but I didn't really like the idea of a front bench seat and having one of the kids up the front with just a lap seat belt. So the idea stalled for quite a while, until I found the old Chev square body suburban's. Has a third row seat and all kids can sit in a lap/sash belt. They are not very common here in Oz (the pickups are more common) but I eventually found this one. Its an 89 Suburban, 454 and T400 with a 14 bolt full floating rear end and 2wd. Was a Qld car so had to get it shipped over to my folks place in Perth and I've just driven it back up North. Had a couple of issues on the drive back, water pump started to make a knocking noise (I originally though it was a valve tapping away) and for some reason I lost a massive heap of power a couple hundred kays from home - I developed a strange exhaust leak around the same time so theres a possible exhaust restriction downstream. Needs a few little things sorted for rego, brakes need some attention along with the windscreen wipers and a bit of a clean up underneath, and try to reduce some of the steering free play.
Long term plans are just to neaten it up a bit more, add a 4 speed auto or a gear vendors overdrive, then decent exhaust (its too quiet at the moment), cam, intake and maybe some aftermarket heads and that should be plenty for a cruise rig. I'll most likely look at some bigger rims and wider tyres at some point as well
Edited by shanegtr, 03 November 2018 - 12:01 PM.
#2 skap
skap
  • 1,120 posts
  • Name:Skap
  • Car:Mighty VN
Posted 03 November 2018 - 12:52 PM
Geez that’s ugly :)
#3 Shiney005
  • 9,718 posts
Posted 03 November 2018 - 01:20 PM
I had a K30 ute the same colour here a while ago as a parts car. The one that we did up is awesome to drive. The bench is big enough to take a cricket team!
#4 shanegtr
shanegtr
  • 533 posts
  • Name:Shane
  • Car:LJ 2 door
Posted 03 November 2018 - 02:34 PM
Geez that’s ugly :)
Its only ugly if you pretend that Ford never built the AU :D
Edited by shanegtr, 03 November 2018 - 02:34 PM.
#5 limo
limo
  • 2,673 posts
Posted 03 November 2018 - 06:04 PM
bloody huge, be tight in shopping centres
but looks nice
#6 shanegtr
shanegtr
  • 533 posts
  • Name:Shane
  • Car:LJ 2 door
Posted 03 November 2018 - 07:36 PM
Has the worlds worst turning circle to match its size. Not that I've taken it to a shopping centre carpark (unless you class supercrap, repco etc.. as shopping centres :P), but it hasn't been too bad - takes up the full bay however. The previously mentioned turning circle is the issue with manoeuvring it around into parking bays - you need a couple of stabs at it
