Dear Torana friends,
Still having a karfuffle with loosing oil pressure in tight curves at the Nürburgring by using racing slicks.
I need to stay with a wet sump by historic racing regulations.
The sump and pickp im using is from high energy , Filled with 6,5 litre of oil. ( Can it be used with more oil ? )
As i did read at the Aussie V8 Forum that its not a oil pan issue by gravity more then a Oil return from cylinder heads problem.
There is a external drain back recommended at the rear of the cylinder heads to avoid that oil returns to sump much better.
Not sure what i need to do when i take out the engine.
Options:
1. External oil lines from rear of cylinder heads to oil pan. Or at the front of the cylinder heads into the timing chain cover housing.
2. Crow pushrods with restricted oil holes.
3. Plug into the timing chain greasing valve
4. Baffeled valve into the intake manifold.
5. Hose from dip stick tube to valve cover
Also i didnt get ever oil pressure when starting without ignition.
Swap oil from 10W60 to 20W50 Penrite didnt make a difference.
When engine was cold i had approx 58psi when hot at race track 21psi - 29psi at above 3000rpm. Sometimes a total loss at idle.
Thats why i will change this winter the oil pump system to a Dodge/Chrysler Mopar pump and try to find out what this does to the engine.
Has somebody experience with those modifications ?
Uwe
