has anyone used the holley sniper of fitech efi,would they be suitable for a turbo holden 6 20 psi.
efi
Posted 29 November 2018 - 05:03 AM
Posted 29 November 2018 - 12:40 PM
I am running a Holley throttle body with the Holley HP computer, Love it. its very easy to set up and easily adjustable with self tuning or full manual tuning. I only had to make a couple of setting changes to get it to work perfect for my engine. You can control fans, AC, fuel pumps, nitrous, boost and many other accessories if needed. Or add to your system later using the program to configure input and output channels. I can also get the ECM to trigger warning scales or limit warnings lights for just about any parameter. The Holley HP system is a bit more expense over the snipper or fi-tech but worth every cent.
Posted 29 November 2018 - 07:34 PM
I'm pretty sure that the sniper does "not" work with boost, only nitrous. Neither does ez efi, fast do a boost style efi system, "self learning aswell, the fi tech is meant to be the cheapest. The edelbrock is the dearest, the only thing that let's them down i think is that you can't run an electronic automatic box like the 6l80e of off them, to me that's what is missing from being a brilliant idea, pick one that can also plug in to a laptop, if you're after a really good tune though. Gary.
Posted 30 November 2018 - 07:36 AM
If you are goint to run a lazy mans transmission either now or in the future, the Holley HP and Terminator ECM can drive most of the late model trannies. Not that its probably needed, but the Terminator series also caters for traction control and fly by wire. Both systems are designed to control water injection which could be handy for a Holden 6 running 20psi boost.
Posted 01 December 2018 - 07:48 AM
Draw thru or blow thru? The Fitech is supposedly good for 25psi in blow thru applications.
