Hi
I am having a problem with when I sit idling in the SS and the revs are low the brake pedal starts to slowing sink. Raising the revs fails to lift the brake pedal. When I freshened the motor up and put it back together the brake booster failed so I had it reconditioned. Also when you brake there is a fine line to a quick stop and locking it up.
I have the brake booster reconditioned 8 months ago and have changed out the vac pipe to the brake booster to ensure no vacuum leaks. Bled the brakes twice. Was thinking it can only be master cylinder or proportional valve. Anyone had this problem so I can tackle the correct part for replacement
Edited by BradleySS, 01 December 2018 - 12:27 PM.
