Main Power Wire?
4 replies to this topic
#1 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 03 December 2018 - 12:51 PM
Just got my LS1 running
Is there an identifyable single wire from the Torana fuse box that i need to connect to the Battery for the Torana side of things? Or many?
I don't want to just hook things to the battery to try
#2 rodomo
  • 17,997 posts
Posted 03 December 2018 - 09:11 PM
Torana has a red wire direct from the starter that feeds the fuse box via a fusible link standard.
Also has a pink wire that feeds the fusebox via the ignition switch.
#3 Rockoz
Rockoz
  • 3,961 posts
  • Name:Rob
Posted 04 December 2018 - 07:42 AM
Also has another wire feeding the fuse box from the headlight switch.
But the one that feeds everything is as stated, the wire from the starter with the fusible link.
It feeds all the other stuff.
#4 hanra
  • 10,831 posts
Posted 04 December 2018 - 08:14 AM
Nope, only the one wire feeding the fuse box.
#5 Rockoz
Rockoz
  • 3,961 posts
  • Name:Rob
Posted 05 December 2018 - 07:07 AM
4 by that diagram Brad.
Every one of the wires in the centre plug feeds power to the fuse box.
The other 3 wires go through other control switches before coming in though.
But all power comes from the starter via the fusible link initially.
