Car stand positioning
5 replies to this topic
#1 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 13 December 2018 - 06:09 PM
To place your car on car stands for long term storage and to stop flat spotting the tyres can the stands be placed directly underneath each front lower suspension arm directly below the coil spring (LJ Torana) naturally with a piece of soft timber between the bottom suspension arm and stand so the suspensions sits under its natural weight. Rear stands would be on the outer ends of the diff housing. Just don't like the idea of jacking up the front and letting the front suspension and just letting it hang down.
#2 71xu1
71xu1
    Dave
  • 1,263 posts
  • Car:LC GTR XU1
Posted 13 December 2018 - 10:00 PM
Perfect, but would not use a piece of timber no real advantage and may actually slip.
#3 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 14 December 2018 - 02:46 AM
Good when you have ply tires.Drag wrinkle walls etc.radials are okay.
#4 RallyRed
  • 7,836 posts
Posted 14 December 2018 - 08:52 AM
Reckon you are onto it mate.
Like you say, better to let it sit under its own weight.
As an aside, I have always found with at least the LC/LJ cars, if you support them on a hoist (i.e. lift via chassis rails) after a while they ""droop"" a bit and the doors no longer open or close properly.  Of course, it goes back to normal once the weight gets put back on the wheels.
Moral of the story - place the stands as close as you can to the wheels.
#5 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 14 December 2018 - 11:16 AM
Thanks guys. Just wanted to make sure as never owned a car where I had to do this.
#6 rexy
rexy
  • 3,584 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 15 December 2018 - 12:19 PM
I personally do like to use either a piece of wood (2cm thick) or rubber between the stand and the car for the front end. Stops scratches and gouges. For the axle tubes on the diff some thick rags are enough given the shape of most stands versus the curve of the axle tubes.
