lj high beam dash light is always on
8 replies to this topic
#1 originalglenn
originalglenn
  • 594 posts
Posted 31 December 2018 - 11:12 PM
as it says the blue light is always on (its not as bright when on low beam)
thought it might be a bad earth but i checked so im not sure any ideas?
#2 Rockoz
Rockoz
  • 3,969 posts
  • Name:Rob
Posted 01 January 2019 - 09:35 AM
Check the earths at the headlights, park lights, and the earth behind the dash.
#3 S pack
  • 15,541 posts
Posted 01 January 2019 - 10:20 AM
Single blue wire feeds power from the headlight switch to the dipper switch. The dipper switch then feeds power to the low beam via  the tan wires and power to the high beam and high beam indication light via the light green wires.
I'd be checking the dipper switch.
#4 RallyRed
  • 7,850 posts
Posted 01 January 2019 - 11:57 AM
Maybe a poor earth on one of the headlights?...current going through the low beam fillament, and due to no good earth at the headlight, then going back via the hi beam fillament and through the High Beam globe.
The offending headlight should be duller than the good one....assuming they are not both dodgey.
All this also assumes your installation is factory correct.
#5 originalglenn
originalglenn
  • 594 posts
Posted 01 January 2019 - 08:14 PM
ok thanks ill start with the
dimmer switch
#6 S pack
  • 15,541 posts
Posted 01 January 2019 - 09:02 PM
Col's thoughts about the headlight earths are worth investigating. Probably best to check the earths first before the dipper switch.
#7 LJ RB30
LJ RB30
  • 975 posts
  • Name:Trevor
Posted 01 January 2019 - 10:10 PM
Yep earths are first to look at with stray voltages
#8 Rockoz
Rockoz
  • 3,969 posts
  • Name:Rob
Posted 02 January 2019 - 07:49 AM
I doubt it will be the switch.
The symptoms you describe would happen about once in a million faults.
Earths at the headlight, or a really bad connection to the earth connector in the headlight plug.
I consider that as checking the earths anyway.
There is a remote possibility that the filaments have lost contact with the earth in the globe.
I have seen that once, but it was also due to a bad connector in the plug.
#9 Rainman
Rainman
    Pain in the ar$e
  • 799 posts
  • Name:Ray
  • Car:SS Hatch
Posted 02 January 2019 - 12:18 PM
Hey Glen,
This happened to myself two days ago. I replaced the H4s with some 100/90 and now my high beam light stays on. It was fine before I changed the globes. Ray
