LX SL Hatch questions
12 replies to this topic
#1 limo
limo
  • 2,672 posts
Posted 11 January 2019 - 12:21 PM
dragged this out of hay shed last week , front calipers seized
put the mags on so tyres legal,
going to drive it and tidy up as I go, sold some of my others
Attached File  IMAG0730.jpg   40.77K   19 downloads
the side bump strips are they after market add ons?
Attached File  IMAG0731.jpg   134.11K   9 downloads
the wood piece in the rear section is just bit of chip board, that original?
is it one piece and  are there any hinges ?
#2 Bigfella237
  • 4,371 posts
Posted 11 January 2019 - 01:15 PM
The side body mouldings were standard on SL and Sunbird models I believe, the SS had a full length decal instead.
Although you could obviously get aftermarket strips, but your photo isn't good enough to tell the difference?
#3 VIXL34s
VIXL34s
  • 177 posts
  • Name:jeff
  • Car:2x L34s,+ HZ GTS, A9X HATCH.A9X SEDAN
Posted 11 January 2019 - 05:48 PM
Looks a bit like chip board peice could be original
#4 matty
matty
  • 36 posts
  • Car:1976 LX Hatch
Posted 11 January 2019 - 07:10 PM
Yep chipboard looks original it would have had a big piano hinge running up the middle. Mick at Torana RPA has these as a kit i think if you need it mate. (the metal, not the timber)
Edited by matty, 11 January 2019 - 07:10 PM.
#5 limo
limo
  • 2,672 posts
Posted 12 January 2019 - 05:01 PM
yes the SS had stripes I had one late 70s
Attached File  IMAG0735.jpg   85.97K   7 downloads
this any better to see?
they look a bit rough and uneven the way they are sitting on panelsAttached File  IMAG0735.jpg   85.97K   7 downloads
#6 Bigfella237
  • 4,371 posts
Posted 12 January 2019 - 05:20 PM
Yeah dunno, they might be the factory mouldings...
If you can remove the side trim and get a look inside the rear quarter at the back near the tail light you'll see the factory mouldings are secured from the inside at the rear of the strip with a kind of speed nut (I think they used to call them)?
#7 308 Sunbird
308 Sunbird
  • 966 posts
  • Name:Stuart
Posted 12 January 2019 - 06:40 PM
Little Brother has a genuine SL hatch- not sure the strips look like yours will need to check.
#8 CI 0308
CI 0308
  • 736 posts
  • Car:77 LX SS, VX SS
Posted 12 January 2019 - 06:43 PM
They dont look factory to me, just aftermarket sticky backed ones.
#9 S pack
  • 15,538 posts
Posted 12 January 2019 - 06:58 PM
Agree, GMH usually had proper caps on the ends to finish them off, not leave raw cut ends like those in the pics.
#10 claysummers
claysummers
  • 3,332 posts
  • Name:Clay
Posted 12 January 2019 - 07:31 PM
Factory or not it’s pretty obvious that the drop from door rear to quarter panel is entirely consistent with the decal sticker line above. Both the sticker and the bump rubber trim were in the same alignment. Then the door dropped.........
Clay
#11 limo
limo
  • 2,672 posts
Posted 12 January 2019 - 09:29 PM
they are fixed with double sided tape, can see it looking down
#12 Obey 1
Obey 1
  • 414 posts
Posted 13 January 2019 - 09:45 AM
Have a look at these photos, I have two sets of stripes on my SL hatch ,the black would be factory as it held on by pins and the top strip well I guess the previous owner really didn't want to damage his car. I like em as I haven't had a dint from opening my door or Vica versa.Attached File  IMG_0774.JPG   155.34K   8 downloads
Sorry..don't know why my car is upside down ??
#13 CI 0308
CI 0308
  • 736 posts
Posted 13 January 2019 - 01:37 PM
Here is a screen shot of the GMH Torana Hatchback advert of the day. It shows a Royal Plum SL Hatchback with the factory strips.
TORRRAANNA, its loaded with smart thinking !!!
Edited by CI 0308, 13 January 2019 - 01:41 PM.
