So Rare Spares bolts to mount a gearbox to a 6 cylinder engine have a shank and their bolts for a V8 to gearbox dont.
Does anyone know if the factory bolts for the V8 to trans bolts have a shank or not?
Posted 26 January 2019 - 04:36 PM
Posted 26 January 2019 - 11:00 PM
It's because the 6's deliver way more torque and the shanks act as auxiliary dowls.
Posted 27 January 2019 - 11:12 AM
😯It's because the 6's deliver way more torque
Posted 27 January 2019 - 11:32 AM
To be truly trans they would have no shank or nuts
6's are weird
Posted 27 January 2019 - 02:31 PM
I always thought the manual transmission to bellhousing bolts were all the same for 6 & 8 cyl with Aussie M15, M20, M21 & M22.
From memory the original transmission mounting bolts in my LJ don't have a blank shank on them.
Posted 27 January 2019 - 03:07 PM
what gearbox do you have ? some later stuff has longer bolts
Posted 27 January 2019 - 03:57 PM
Posted 27 January 2019 - 04:01 PM
Posted 27 January 2019 - 04:03 PM
6's are weird
Edited by mugginz, 27 January 2019 - 04:04 PM.
Posted 27 January 2019 - 05:46 PM
GMH don't change much so for what its worth mine were set screws. (*83 V8 VH)
OK - with a "shank" (unthreaded section) is a bolt.
fully threaded on the entire length is a set screw.
Bolts are for a specific length application.
Set screws are for a variable length application or generally used to secure an object within or against another object, normally not using a nut .
bolts are generally cheaper than set screws
in some applications you also have to consider:-
Tensile strength is along the axis of the bolt (the hold together strength) shear strength is resistance to two surfaces twisting in opposite directions and "shearing" the bolt that holds them together.
Bolts of the same grade as set screws are generally of a higher shear strength. (Bigger shaft diameter at the shear point - no threads to weaken the shear point)
​In a doweled assembly application shear stress is not applicable, the dowel takes care of those forces.
I have replaced my T5 bellhousing bolts with allen header set screws (H8) just for ease of disassemble. torqued twice and checked - 8 track days OK.
Edited by Balfizar, 27 January 2019 - 05:51 PM.
Posted 27 January 2019 - 06:34 PM
looks like
4 and 6 cyl were 7/16" - 14 tpi x 2" Bolts
8 Cyl were 3/8" - 16 tpi x 1.5 " set screws
which aligns with the photo
Posted 27 January 2019 - 07:14 PM
Set screws are for a variable length application or generally used to secure an object within or against another object, normally not using a nut .[/size]
Posted 27 January 2019 - 07:35 PM
Just a good old m20
From the HX parts catalogue for 6cyl & V8 M15, M20, M21 & M22 4spd.
Bolt & Lock Washer - Transmission to Clutch Housing - All...................................SP2029 ....................QTY 4
The LC, LJ, LH (4,6 & 8 cyl) & LX (6 & 8 cyl) parts books all list the same part number SP2029.
Posted 27 January 2019 - 07:42 PM
is it gearbox to bell housing or bell-housing to motor the op wants ?
if its gearbox to bell housing its whats dave has posted , there all the same
Posted 27 January 2019 - 08:56 PM
Bell housing to block is what I was chasing but the other info is handy.
The parts book I have list the Trimatic to 6Cyl engine as part number 179866 which MTS list as - "Bolt Hex HD 7/16" - 14 X 2" Grd 5" and V8's are 3/8UNC so that clears that up I guess.
The V8 bell housing mounting face includes two fairly decent dowels so I spose Holden decided that was sufficient and going by Balfizar's experience, actually is completely fine.
The Rare Spares part being a set screw sounds like it might be as per factory, but as I've had a few Rares parts not be quite right I wanted to confirm with the community.
Many thanks for all the info and will go with the Rares part.
Posted 27 January 2019 - 09:24 PM
as long as the bellhousing is from a torana, not from like vb-vk commodore or even maybe a UC / WB (the bolts a are longer ) you should be right
Posted 27 January 2019 - 09:37 PM
Good point.
Will check for a part number on the bell housing tomorrow.
Posted 27 January 2019 - 10:58 PM
Late UC (Starfire) and Commodore bellhousings will have a 'pull-fork' clutch release system with a big lug/hole to hold the lower end of the cable...
Older 'push-fork' type systems just have two threaded bolt holes tapped into the side of the housing.
~ The V8 bell housing mounting face includes two fairly decent dowels so I spose Holden decided that was sufficient ~
Also a V8 has six bolts (bellhousing to block) and L6 only has four.
Posted 28 January 2019 - 09:21 AM
Posted 29 January 2019 - 07:01 PM
Turns out the Rares bolts include a shank
They should do as a replacement for the following hopefully
Anyone know the dimensions, etc for the SP2029 trans to bell housing bolts?
Posted 29 January 2019 - 07:16 PM
If anyone has a copy of the "Standard Parts Catalogue" Part No. M37600 it's probably listed in that?
Posted 31 January 2019 - 07:44 AM
The HJ parts manual still includes section 8.899 to 8.991 listing many of the standard parts
SP2029: 3/8"-16 x 1 3/8" with washer
Posted 31 January 2019 - 09:24 AM
Many thanks for that. I'll go to the bolt shop today. I looked through the LC parts manual section 8.899 to 8.991 and I couldn't find it in there and the only link I've found so far for the HJ manual links instead to the HK manual. Is a download for the HJ manual still around somewhere?
Posted 31 January 2019 - 11:29 AM
Yep, the link to the HJ manual was fixed. Its in the same folder as the HK one
https://www.dropbox....kFWNWL6hYa?dl=0
