LX SL Hatch
30 replies to this topic
#1 limo
limo
  • 2,672 posts
Posted 29 January 2019 - 07:11 PM
Shouldn't start this project until I finish the other 3 on the go but doing it differently
Usually strip back to bare shell then slowly rebuild, very very slowly
this time going to do bit each month so it can be driven to Cars & Coffee first Sunday each month
with aim of finished by end of the year
Attached File  IMAG0753.jpg   597.21K   17 downloads
Attached File  IMAG0755.jpg   715.45K   17 downloads
Attached File  IMAG0754.jpg   447.97K   15 downloads
#2 limo
limo
  • 2,672 posts
Posted 29 January 2019 - 07:19 PM
going to cheat a bit ,seeing as guards bolt on will use another one rather than repair as wit LC LJ,
searching for left guard found this
Attached File  IMAG0749.jpg   88.74K   14 downloads
Attached File  IMAG0748.jpg   111.56K   13 downloads
there is a sealing strip on one of the guards attached with plastic "studs"
is this standard and are the seals available ?
#3 308mate
308mate
  • 523 posts
  • Name:scott
  • Car:76 SS hatch (Royal Plum, Chevron Chamois interior), HQish Van (Orchid Metallic)
Royal plum metallic, my favorite colour! Bring it on.
#4 limo
limo
  • 2,672 posts
Posted 29 January 2019 - 07:25 PM
next question
the lower dash section is butchered for radio
I found there are replacement facias
Attached File  IMAG0752.jpg   155.66K   13 downloads
another I can use to replace
Attached File  IMAG0751.jpg   365.72K   13 downloads
question how is the facia piece fixed in place?
I want to remove the black one and put a new wood grain in
#5 rodomo
  • 17,998 posts
Posted 29 January 2019 - 10:35 PM
Dreamin buddy...………..you know it...………...I know it...……….but best of luck!
#6 Bigfella237
  • 4,371 posts
Posted 30 January 2019 - 04:44 PM
Similar thread here:
http://www.gmh-toran...console-repair/
#7 limo
limo
  • 2,672 posts
Posted 30 January 2019 - 07:10 PM
Yes I've seen that However Kingswood Country have new replacement, black, silver, wood grain So I can get new wood grain and replace the black on the good dash piece but don't know how to remove the black pieces Would have thought someone had done it
#8 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 30 January 2019 - 07:15 PM
I haven't taken a black lower dash facia off but the lx woodgrain ones are glued on. I would guess the black ones are the same.
#9 arrimar
arrimar
  • 3,121 posts
Posted 31 January 2019 - 09:13 AM
Yes standard on LH, not sure if remained all the way through to late LX, no not available.
#10 RIM-010
RIM-010
    DON'T PANIC
  • 8,075 posts
  • Name:Tim
  • Car:LJ 2 Door - HQ Premier
Posted 31 January 2019 - 09:50 AM
Another one!
Reminds me (again) I have to come up the hill and see if there's anything out there for me...
#11 limo
limo
  • 2,672 posts
Posted 31 January 2019 - 04:52 PM
thanks
I might fish oil the section then seal it
that would be why the guard rusts through along the edge
#12 limo
limo
  • 2,672 posts
Posted 31 January 2019 - 04:55 PM
I have some other black ones that have been cut so might experiment with one of those first
should be able to use heat gun I would expect
#13 limo
limo
  • 2,672 posts
Posted 31 January 2019 - 06:04 PM
Oh Ye of little faith
Attached File  randolf1.JPG   78.01K   11 downloads
Attached File  IMAG0658.jpg   446.58K   12 downloads
basket case when I bought it, needed floors , front back screen rust
took 12 months back on road
Attached File  LCGTR4.JPG   46.66K   12 downloads
Attached File  ATD3_zpsb7a83dd1.JPG   138.99K   14 downloads
this one 2 years but much fussier
complete car stripped as seen and restored
if I keep Hatch on road and driving it I will work on it
#14 rodomo
  • 17,998 posts
Posted 31 January 2019 - 10:16 PM
OK...………..no need to rub it in! :spoton:
#15 limo
limo
  • 2,672 posts
Posted 06 February 2019 - 05:59 PM
Started Monday with bonnet
Attached File  IMAG0761.jpg   93.67K   10 downloads
bare metal both sides
forgot to take pics until started painting, etch primer
the 2 pack primer filler arrives tomorrow
Attached File  IMAG0762.jpg   110.03K   10 downloads
Attached File  IMAG0764.jpg   112.88K   11 downloads
Attached File  IMAG0769.jpg   60.03K   11 downloads
left guard same, bare metal both sides then etch
#16 limo
limo
  • 2,672 posts
Posted 06 February 2019 - 06:07 PM
took out the seats for repairs
Attached File  IMAG0767.jpg   350.55K   14 downloads
Attached File  IMAG0768.jpg   256.71K   12 downloads
gone to local trimmer
had quick look under carpet, original underlay still there, floor good on driver side
will check passenger later, need tool to remove plastic studs in kick panel
#17 limo
limo
  • 2,672 posts
Posted 18 February 2019 - 04:10 PM
up date
front floors
Attached File  IMAG0773.jpg   99.4K   8 downloads
have cleaned a bit since and few small spots of daylight
will have to do some test welds to find out how thick metal is
and how much to cut out to replace
back floor section good
#18 limo
limo
  • 2,672 posts
Posted 18 February 2019 - 04:17 PM
back on the road for club cruise yesterday
Attached File  IMAG0779.jpg   110.14K   10 downloads
Attached File  IMAG0784.jpg   96.52K   11 downloads
2 pack primer over etch
small dent at nose point to fill before sealing paint
needs radiator replaced or re cored, got a bit hot up hills
#19 limo
limo
  • 2,672 posts
Posted 03 March 2019 - 06:38 PM
coffee and cars today so hatch back on the road with some done
Attached File  IMAG0786.jpg   185.21K   10 downloads
wire brushed cleaned back
will need to do rubber bushes / mounts for cross member
so will take it out strip clean paint and re assemble, on list
Attached File  IMAG0787.jpg   279.38K   7 downloads
looks bit dodgey
Attached File  IMAG0789.jpg   455.02K   7 downloads
repaired but not real happy, will have another go when engine comes out to do bay
or may replace with Rares patch
#20 limo
limo
  • 2,672 posts
Posted 03 March 2019 - 06:46 PM
Attached File  IMAG0790.jpg   105.12K   10 downloads
etch prime, chassis black paint then stone guard
inside of guard same
Attached File  IMAG0791.jpg   161.05K   9 downloads
driving again
took the rubber strips off, 3 different colours, under, above and below strips
have 3 weeks until next event so front screen comes out Tuesday and see condition
get it repaired painted and screen back in before then
#21 Bigfella237
  • 4,371 posts
Posted 03 March 2019 - 08:43 PM
I hate to see someone trusting those little floor jacks like that, I've seen more of them collapse than I care to think about... at the very least you could slide the wheels under the chassis rails to take some of the weight off your feet when they get pinned! :cry:
My old boss used to walk up to the front of the car and let the jack down without warning, if the car crashed to the ground because we didn't have jack stands under it we'd get a kick up the backside!
I can't believe you don't even have rust behind the bonnet hinges, that looks like a real nice shell. At this pace you'll be pouring on purple in no time!
#22 limo
limo
  • 2,672 posts
Posted 04 March 2019 - 05:26 PM
yes usually slide wheel under car but couldn't find my milk crate to sit on so was sitting on the wheel.
no part of my body legs or feet under car while working
had people I knew die under cars when jacks went bad
#23 limo
limo
  • 2,672 posts
Posted 04 March 2019 - 05:31 PM
there's purple under the bonnet but wrong shade so will have to do it again
bit rough anyway
#24 GMH-01X
GMH-01X
    Drive Fast Take Chances
  • 1,135 posts
  • Name:Aaron
  • Car:1977 Hatchback
Posted 04 March 2019 - 07:08 PM
Hey Limo
How'd you go with repairing your seats
#25 limo
limo
  • 2,672 posts
Posted 05 March 2019 - 03:42 PM
windscreen out
Attached File  IMAG0792.jpg   317.79K   7 downloads
as expected rust
Attached File  IMAG0793.jpg   79.79K   7 downloads
rest of it like this
Attached File  IMAG0794.jpg   107.63K   7 downloads
