LX SL Hatch
30 replies to this topic
#26 limo
limo
  • 2,671 posts
Posted 05 March 2019 - 03:45 PM
Hey Limo
How'd you go with repairing your seats
only the bases needed work, had a spare seat so swapped that base into one and the other has gone to local trimmer to recover.
need to get new backs but haven't decided where to buy yet
#27 GMH-01X
GMH-01X
    Drive Fast Take Chances
  • 1,135 posts
  • Name:Aaron
  • Car:1977 Hatchback
Posted 06 March 2019 - 06:22 PM
My though was you may have been getting the bases re-stitched using the original covers, my drivers seat has some stitching coming apart that I'll be taking it to my local trimmer to maybe re-stitch but more than likely I'll purchase new SS seat covers
Cheers Aaron
#28 limo
limo
  • 2,671 posts
Posted 07 March 2019 - 05:00 PM
no too badly split and nothing to stitch
$300 to have base recovered in matching vinyl
pick up on Monday and see
#29 limo
limo
  • 2,671 posts
Posted 01 April 2019 - 04:57 PM
Club cruise yesterday so back together so could drive
stripped all the paint and stuff off of the roof and around screen
Attached File  IMAG0809.jpg   106.87K   3 downloads
surprised how soft the roof is moving in with pressure
could easily put nasty dents in it
also lots of tiny rust pits so used conditioner
Attached File  IMAG0814.jpg   78.31K   3 downloads
basically phosphoric acid which reacts with and locks in rust
then etch primer and 2 pak primer filler, will need to be rubbed back and more filler to get
rid of the pock marks from rust pits
Attached File  IMAG0821.jpg   351.97K   4 downloads
bit of double work as windscreen will come out again to paint but I put it back dry so not much time
won't need to clean off sealer
only a week to next event so might do the hatch and hope not too much rust to fix
have a spare so will pick the best and easiest to fix
#30 limo
limo
  • 2,671 posts
Posted 06 May 2019 - 05:45 PM
spare Hatch door better condition only bad section
so will repair that and fit
Attached File  IMAG0874.jpg   78.68K   2 downloads
didn't feel enthused about doing it now so went to RH guard
Attached File  IMAG0855.jpg   247.77K   2 downloads
same thing cleaned wire brushed, then etch prime paint and stone guard
Attached File  IMAG0856.jpg   271.04K   2 downloads
bare metal etch, paint and stone guard inside
"                      "    then 2pac primer
Attached File  IMAG0873.jpg   285.8K   2 downloads
Back together went to Coffee and Cars yesterday
#31 limo
limo
  • 2,671 posts
Posted 06 May 2019 - 05:59 PM
cleaned up driver's floor
Attached File  IMAG0847.jpg   74.9K   2 downloads
bit of work, hole through both panel sections, inside and out
you can see the ground through floor
Attached File  IMAG0848.jpg   131.61K   2 downloads
this shows inside repair of hole but floor not finished I have to replace part of floor
on grinding clean lots of pin holes
fortunately have a donor LX
not sure what will be next gear box needs replacement suddenly noisey
also one  cross member mounting bolts missing
sheared off in chassis thread so needs to be drilled out and tapped
