Brake lines for HQ Front disc conversion
5 replies to this topic
#1 Torana_Boy
Torana_Boy
  • 157 posts
  • Name:Danyon Michalkowski
  • Car:UC torana
Posted 01 February 2019 - 06:03 PM
I’ve done myself a HQ brake upgrade on my UC to compliment the VN diff going in the rear.
No real issues, pulled out the check valve and will be replacing the brass fittings in the M/cylinder and grinding a bit off the calliper mount.
I’ve gone to check out the flex brake lines and realised neither the HQ or UC lines will work due to the location of the HQ brake line fitting position.
Has anyone come up with a solution that avoids the flex line getting damaged?
#2 _mervx_
_mervx_
Posted 02 February 2019 - 09:09 AM
HI, have a look at the "HQ brake conversion thread above .Last page 9.Or google "Hq brake tutorial"
Edited by mervx, 02 February 2019 - 09:12 AM.
#3 Cook
Cook
  • 1,505 posts
Posted 03 February 2019 - 09:03 AM
Hi Danyon. Someone more knowledgeable will confirm or otherwise but is it feasible to swap the stub axles over (left to right) as per a hoppers Stoppers upgrade and run the calipers to the back like that?  They then run the cable behind the stub axle.  I've just done this with my hoppers. There is thread on that "hoppers stopper conversion". Good luck with it. Cheers Ron
Edited by Cook, 03 February 2019 - 09:04 AM.
#4 Terry Marsh
Terry Marsh
  • 43 posts
  • Name:Terry Marsh
  • Car:LH SLR / LX SS Hatch
Posted 04 February 2019 - 06:20 PM
Torana_Boy, see attached Photo of my PBR Caliper - I got a Machinist Mate of mine to machine & drill the front of the Caliper exactly like an L34 - we then just put a Bolt & Copper Washer in the HQ Position Hole.
#5 rexy
rexy
  • 3,588 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 04 February 2019 - 10:10 PM
Dunno if the mounting point for the flex line to hard line is different on UC vs LX?
You can use the standard HQ lines if you have the cakipers on the rear. Caliper do tend to bump into the UCA though. You can either fit a steering stop or clearance the UCA.
#6 Terry Marsh
Terry Marsh
  • 43 posts
  • Name:Terry Marsh
Posted 04 February 2019 - 10:37 PM
The way I mounted mine suits std LX Brake Hose + Caliper cleared UCA but I made 10mm High Half-Moon Notch above Caliper for safety
