Do I run DOT 5 or DOT 3 in my brakes/clutch system
4 replies to this topic
#1 evl666
evl666
  • 267 posts
  • Car:71 LC 73 LJ
Posted 03 February 2019 - 03:08 PM
Pros and cons for dot 5 besides the fact it doesn’t melt paint? Can I run dot 5 or will it kill my seals in the master cylinders?
#2 dattoman
  • 16,470 posts
Posted 03 February 2019 - 03:22 PM
Dot 3 is fine
Never use DOT5 in anything
#3 evl666
evl666
  • 267 posts
  • Car:71 LC 73 LJ
Posted 03 February 2019 - 03:33 PM
The question is why?
#4 _Arron_
_Arron_
Posted 03 February 2019 - 09:24 PM
Link
#5 dattoman
  • 16,470 posts
Posted 03 February 2019 - 09:44 PM
SIlicone fluid aerates which will leave you with bubbles in the line and no pedal
Its also compressible... not good for brakes
Its also not hygroscopic... so while it doesn't absorb moisture... the moisture that gets in stays as water droplets that happily boil off at temp and you lose pedal
