Rod bolts for Holden 6 with starfire rods (Blue/Black motor)
10 replies to this topic
#1 Com_VC
Com_VC
  • 411 posts
Posted 05 February 2019 - 02:27 PM
Hi,
Need to buy some conrod bolts, are the chev bolts still the only option?  Do I need to buy 16 when I only require 12?  Factory bolts still available?  Any other options these days?  Are the ones listed on eBay a decent price or should I shop elsewhere?
https://www.ebay.com...&frcectupt=true
#2 Ice
  • 15,122 posts
Posted 05 February 2019 - 05:21 PM
Go ARP
#3 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 05 February 2019 - 07:12 PM
Yep, i would run the arp bolts.
#4 Com_VC
Com_VC
  • 411 posts
Posted 06 February 2019 - 04:44 PM
Guess I will have to put the four spares aside and then eventually if I end up with another two sets I will have enough of the spares for a forth set. :)
#5 _imperial engines_
_imperial engines_
Posted 08 February 2019 - 05:58 PM
Same as red 308 . Go ARP , cheap enough. Don't forget to resize and there is a lot of weight saving to be had by radius milling the balance pads top and bottom .
#6 Com_VC
Com_VC
  • 411 posts
Posted 30 March 2019 - 10:03 AM
Could someone give me the correct part number, some are saying small journal chev bolts will fit (327) others are saying red 308 bolts?  Just don't want to end up with the wrong bolts.
Also imperial engines, do you have any photos of the radius milling of the pads available?
#7 I'm a Red Motor fiend
  • 758 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 30 March 2019 - 02:40 PM
The link in your first post is correct. 11/32" bolt, ARP 134-6001.
They will fit Holden V8 as above, small block Chev as above and Holden Blue/Black/Starfire rods.
#8 Com_VC
Com_VC
  • 411 posts
Posted 30 March 2019 - 04:09 PM
This is confusing, there seems to be a few variations for the Holden V8 as well.
205-6001
134-6403
134-6001
#9 Com_VC
Com_VC
  • 411 posts
Posted 30 March 2019 - 04:12 PM
and another 135-6002
#10 I'm a Red Motor fiend
  • 758 posts
  • Name:Adam
Posted 30 March 2019 - 04:30 PM
134-6001.
#11 Com_VC
Com_VC
  • 411 posts
Posted 30 March 2019 - 05:00 PM
Ok will go with those :)
