Fuel leaking from carb onto exhaust manifold, safe to drive?
24 replies to this topic
#1 _Hipotur_
_Hipotur_
Posted 06 February 2019 - 06:09 PM
Heya!
Our LJ has triple strombergs, the middle carb is leaking onto the exhaust manifold (i assume thats what is directly below it). Not entirely sure where the leak is coming from on the middle carb, i want to say the bottom of it, but i dunno. Its quite a steady drip that only starts when the car is on, it drips every .5 to 1 second.
Obviously we want to get this fixed! My question is, is it safe to drive for 20 mins to get it to our mechanic?
Fuel leaking onto an exhaust manifold that gets hot... seems dodgy as frOck to me!
#2 76lxhatch
  • 7,152 posts
Posted 06 February 2019 - 06:21 PM
You said it. Which do you think you will regret more, spending a little more money trailer it (or have someone come to you), or watching it burn from a fault you knew existed...?
#3 joeseph
joeseph
  • 108 posts
  • Name:Joeseph
  • Car:LJ XU-1 ex-owner
Posted 06 February 2019 - 06:55 PM
My XU-1 used to do that when not run for awhile - I was nervous as hell about it but it did calm down after 30 mins or so of running. The guys at the testing station said it was due to gaskets or o-rings drying up with no fuel when sat for a few months (while passing the car for a warrant of fitness as 'nothing in the regs about leaking fuel from the carbs..). I always carried an extinguisher just in case.
#4 muzzta
muzzta
  • 264 posts
Posted 06 February 2019 - 07:02 PM
Safety first, similar issue but had a power steering problem, ended up a steering rack, but mechanic didn't reconnect power steering fluid connections correctly after some testing, leaked, caught on fire, one fire ext didn't put it out, luckily had two on hand in the boot.
Scary seeing flames out the bonnet while driving.
Tip carry more than one fire ext.
Insurance covered it which was great.
Muz
Edited by muzzta, 06 February 2019 - 07:07 PM.
#5 _Hipotur_
_Hipotur_
Posted 06 February 2019 - 08:34 PM
interesting joseph, that is the case with ours, hasnt been run for 2 months. Maybe i can put something under the leak to catch the fuel and idle it for 15+ mins.
Edited by Hipotur, 06 February 2019 - 08:35 PM.
#6 caterham2
caterham2
  • 348 posts
  • Location:Mansfield North East Victoria not the other one in QLD
  • Car:Ford Focus RS AWD Gone over to the dark side .. Mercedes-Benz SLK350 Ford Cortina 2 door MK1 Twin Cam
Posted 06 February 2019 - 09:24 PM
Hipotur, ever heard of the Darwin Awards?
#7 S pack
  • 15,538 posts
Posted 06 February 2019 - 09:37 PM
If it is O-rings and/or a gasket that has dried out you don't need to run the engine just need fuel to get to the seal/gasket to make it swell up and seal.
With the fuel you say has been dripping from the carb if it hasn't sealed itself up by now it isn't going to.
If you can't replace the offending O-ring/s or gasket or possibly even a faulty needle & seat in the fuel bowl yourself then tow or get the car towed to your mechanic.
#8 ozyozyozy
ozyozyozy
  • 944 posts
Posted 06 February 2019 - 10:37 PM
Analyze the situation here, its fuel, dripping onto an exhaust.
An exhaust gets pretty darn hot and it does that pretty quick. Fuel is highly flammable.
By all means give it a crack, take the risk, drive it and let it burn to the ground.
#9 Balfizar
Balfizar
  • 461 posts
Posted 07 February 2019 - 12:14 AM
Take the manifold and carby's off - take them to a carby specialist and have them overhauled -  replace run and check for leaks.  Bob's your uncle! have I missed something?
Edited by Balfizar, 07 February 2019 - 12:16 AM.
#10 S pack
  • 15,538 posts
Posted 07 February 2019 - 06:23 AM
The owner/s may not be mechanically inclined.
#11 claysummers
claysummers
  • 3,328 posts
  • Name:Clay
Posted 07 February 2019 - 09:15 AM
Petrol requires a spark to ignite. Heat will just cause it to vaporise. That said I wouldn’t risk it.
#12 Rockoz
Rockoz
  • 3,965 posts
  • Name:Rob
Posted 07 February 2019 - 10:31 AM
Not quite right.
In fact very wrong.
Most everything has an ignition point temperature.
Sometimes referred to as autoignition point.
For petrol, this is about 250 degrees C.
Pretty sure exhaust manifolds are capable of being at least this hot.
#13 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 07 February 2019 - 11:13 AM
UM yep, the fact that the 3 carburetors when tunning, need to be balanced. Sure you bench tune them first, but then you fine tune them on the engine.
#14 Balfizar
Balfizar
  • 461 posts
Posted 09 February 2019 - 09:46 AM
To drive it safely to a mechanic, I don't think tune balanced carby's are necessary.
#15 Cook
Cook
  • 1,504 posts
Posted 09 February 2019 - 10:12 AM
Hipotur, I can't comment on your specific situation but I had a leaking carb in my v8 ute and quickly turned to a fire in the valley of the manifold. Glad I had an extinguisher.  Safety first.  If you aren't mechanically minded (like me) pay a little to get it towed as others have suggested, to a carby specialist and drive it home.  Maybe someone in Perth can suggest somewhere to take it. good luck. Ron
#16 _2 girls racing_
_2 girls racing_
Posted 09 February 2019 - 11:39 AM
Mobile mechanic springs to mind.
#17 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 09 February 2019 - 01:39 PM
Yeah, i get your point, i was meaning as a finished & driving scenario. I should have said that. Gary.
#18 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 20 February 2019 - 06:56 PM
I figure for around $250 you can re-kit all three carbies. These arrived today for my car. They don't leak but I am figuring that it won't hurt to run a kit through them. Won't have to worry about engine bay fires as much.
#19 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 21 February 2019 - 06:14 PM
They're the std rebuild option, not the high performance model from Gavin aren't they ? He's a top guy, his stuff is good quality. You'll have no problems with anything from Classic Carb.
#20 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 21 February 2019 - 07:04 PM
Not sure Gary. Didn't know there was a high performance option? I would only want standard anyway. I assume there's no tricks to re-kitting them?. Gary do you happen to know anyone close to Gold Coast who can soda blast the carbies whilst they are off? I think that's what they do now to clean them up?
#21 arrimar
arrimar
  • 3,121 posts
Posted 21 February 2019 - 08:08 PM
Call Ross at Carbo-tune at Tweed Heads.
https://www.carbotune.com.au
#22 henry57
henry57
  • 37 posts
  • Name:Stephen
  • Car:LJ GTR XU1 and L34
Posted 27 February 2019 - 09:10 PM
Often the middle carb on triple strombergs leaks because of the needle and seat. Gunk in the fuel line tends to go straight through to the middle carb. I’ve seen it lots of times.
#23 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 28 February 2019 - 07:18 PM
I'll be honest with you, two of my carbies were also dripping but not during running only when it cooled off.(as was sitting in a shed for 20 years) Dry as a bone whilst running. I just counted the turns IN and then unscrewed the large brass nut on the base of each carby and replaced the 'O' ring on it and the smaller knurled nut 'O' ring. Less than $5 to buy then used vasoline on them and screwed them in all the way and counted turns out. Fixed. I'm not exaggerating it was truly simple. The hardest bit it the front carby brass nut
#24 S pack
  • 15,538 posts
Posted 28 February 2019 - 09:08 PM
I gather you removed not only the jet adjuster but the whole jet holder, including the jet from the carby body.
Did you centre the jets correctly when you screwed them back in?
Have you checked the mixture needles are not jamming or excessive resistance in the jets with the air valves closed against the bridge?
#25 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 28 February 2019 - 09:42 PM
All good Dave, he's about re kit them ect. Hopefully all good then.
