Positive wire to battery
18 replies to this topic
#1 Chriso0327
Chriso0327
  • 68 posts
  • Name:Chris
  • Car:Torana
Posted 08 February 2019 - 12:49 PM
Is there supposed to be a positive wire in wiring harness to battery?
#2 hanra
  • 10,832 posts
Posted 08 February 2019 - 01:11 PM
Yep. I’m positive about that.
#3 S pack
  • 15,538 posts
Posted 08 February 2019 - 02:15 PM
Positive wire in harness has the fusible link and connects to starter motor, which in turn connects to battery by a much thicker cable.
If you have any negative feedback please keep it to yourselves.:)
Edited by S pack, 08 February 2019 - 02:18 PM.
#4 RallyRed
  • 7,841 posts
Posted 08 February 2019 - 05:25 PM
As per Spack's comment.
I'll try and insulate myself from other comments, as currently, I am energised by making connections with others.
#5 caterham2
caterham2
  • 348 posts
  • Location:Mansfield North East Victoria not the other one in QLD
  • Car:Ford Focus RS AWD Gone over to the dark side .. Mercedes-Benz SLK350 Ford Cortina 2 door MK1 Twin Cam
Posted 08 February 2019 - 06:01 PM
If you want to hear one of my most electrifying comments , just make contact .
#6 UCgazman
UCgazman
    UC's FTW!
  • 1,342 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 08 February 2019 - 06:16 PM
Bunch of bright sparks here...
#7 Ice
  • 15,122 posts
Posted 08 February 2019 - 06:36 PM
Make sure its not terminal
#8 arrimar
arrimar
  • 3,121 posts
Posted 08 February 2019 - 06:51 PM
Ohm g
#9 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 09 February 2019 - 12:08 AM
Be careful! You could be done for assault and battery.
#10 S pack
  • 15,538 posts
Posted 09 February 2019 - 12:35 AM
Well, I must say, it's been a while since I have read a thread that is generating so many alternating thoughts. I feel I have become polarized and drained, so much so that I want to lay down in a field, coil up and recharge in the solar rays.
#11 Bigfella237
  • 4,371 posts
Posted 09 February 2019 - 05:33 AM
This thread certainly seems to have arc'd up all the bright sparks around here
#12 arrimar
arrimar
  • 3,121 posts
Posted 09 February 2019 - 06:41 AM
#13 S pack
  • 15,538 posts
Posted 09 February 2019 - 07:02 AM
Watt?
#14 Cook
Cook
  • 1,504 posts
Posted 09 February 2019 - 08:50 AM
Enough of the dad jokes.  You guys are shocking and revolting.Cheers Ron
#15 Shiney005
  • 9,034 posts
  • Car:Toyota Mirai
Posted 09 February 2019 - 09:39 AM
You see? Now this is why I choose the forum over Facebook.
Attached File  ee25f05075fbadb4aecce8f180d93372.jpg   29.63K   3 downloads
#16 Dr Terry
Dr Terry
  • 3,276 posts
Posted 09 February 2019 - 11:51 AM
To answer Chris's question, there is no positive wire from the harness directly to the battery.
Firstly it depends what series of Torana we are talking, because there are differences in LC/LJ if you have GTR/Sports instruments.
The main battery lead (the thick one) goes directly the starter motor & in most cases the harness positive supply to the dash etc. is connected to this same junction point. On some models there is a thinner (usually red) wire which runs from the battery post to the alternator.
Before I go any further, what model series are we talking about & why the question ?
Dr Terry
#17 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 09 February 2019 - 01:36 PM
Dave, we're not to mention the "polarizer" remember !
#18 GM5735
GM5735
  • 15 posts
  • Name:Geoff
Posted 10 February 2019 - 02:18 PM
As Dr Terry says above, there are a few possibilities.
For LC/LJ 6 cylinder there are two types of positive battery lead possible - 7416627 for cars with an ammeter, and 2806977 for cars without. (There is also a third one, but only for late LJ XU1).
LC/LJ without an ammeter have a 6 gauge black wire (the thick one) and a 12 gauge red wire (the thin one) moulded into the battery terminal, The black goes to the starter solenoid and the red to the alternator output terminal.
LC/LJ with an ammeter do not have the 12 gauge wire in the battery terminal, only the black.
It's hard to be positive about the options for 4 cylinder LC/LJ, so I'll ignore them.
For LH/LX 4, 6 and 8 cylinder all the positive battery cables have the thin red and the thick black cable moulded into the battery terminal.
#19 S pack
  • 15,538 posts
Posted 10 February 2019 - 02:50 PM
12v Positive feed wire in ALL harnesses have a fusible link and connect to the starter motor.
No main power feed wire in any wiring harness in any model Torana connects directly to the battery.
Edited by S pack, 10 February 2019 - 02:51 PM.
