Lc gtr alternator
Posted 18 March 2019 - 06:11 PM
Posted 18 March 2019 - 06:20 PM
Posted 18 March 2019 - 06:25 PM
Posted 18 March 2019 - 08:18 PM
True I think? In the mean time, run the motor and give the alt a wee tap with a hammer and see if it starts to charge. Might just need a set of brushes?Is it true that all I have to do is unplug the reg and just plug in the brown wire into the alternator if I go with an new internal reg one?
Posted 18 March 2019 - 09:23 PM
Posted 19 March 2019 - 07:12 AM
Likely to only be brushes. Which Im pretty sure are still available.
Or perhaps diodes. Again still available.
They rarely burn out windings.
However if a previous attempt was made to repair it without basic gear, it may have torn the slip ring connecting wire off.
That can be repaired, but needs some perserverance with someone knowledgeable about what they are doing.
The entire unit can be tested with a multimeter, but a soldering iron is needed to do the job as well.
