hi a turbo with a draw through carby can have the same tuned with out changing anything from a low altitude to high altitude for drag racing with no ecu or map sensor
altitude
Posted 10 April 2019 - 03:51 AM
Posted 10 April 2019 - 06:31 AM
The carby on a draw though turbo is the same as a naturally aspirated setup because it is open to atmosphere, a blow carb is under pressure from the turbo so is less likely to need adjustment with altitude changes, so if you have a draw through setup you may need to make adjustments with altitdue changes.
Posted 10 April 2019 - 06:41 AM
Posted 12 April 2019 - 04:10 AM
thank you warrenm you are excatly correct i tried to explain this on another facebook forum and i was told in a turbo draw through it dosent make any difference
