Spigot Bearing/Bush Lubrication Proceedure
10 replies to this topic
#1 mugginz
mugginz
  • 230 posts
  • Name:Greg
  • Car:LH Torana
Posted 11 April 2019 - 08:10 PM
Before I go soaking my new spigot bearing in oil over night or forcing oil into it I thought I'd check to see if anyone's had issues when doing this with excess oil contaminating their clutch.
I know some swear by only using a few drops of oil on the spigot while others say soak and then there's forcing oil into it by hand as well.
If there's actual real world evidence that soaking or injecting oil into the spigot causes issues then I guess I'd just go with the three drops method.
Thanks.
#2 rodomo
  • 16,855 posts
Posted 11 April 2019 - 11:39 PM
I just give it a lick of grease…………….never had a problem.
#3 warrenm
warrenm
  • 1,858 posts
  • Car:1972 LJ Torana
Posted 12 April 2019 - 06:20 AM
Same here, just a lick of grease.
#4 Redslur
Redslur
    Has been Torana owner
  • 3,116 posts
  • Name:Gerry
  • Car:VP 5.0L Berlina, VZ CV8 Monaro
Posted 12 April 2019 - 12:12 PM
I'm with them ^^^
Edited by Redslur, 12 April 2019 - 12:12 PM.
#5 Toranamat69
Toranamat69
    Forum R&D Officer
  • 1,855 posts
Posted 12 April 2019 - 12:58 PM
Ive always soaked it in oil over night. Never had an issue.
#6 dron
dron
  • 52 posts
  • Name:Darren
  • Car:UC
Posted 12 April 2019 - 07:24 PM
Back in the dark ages when I was an apprentice I was told to push oil through the Holden sinted bush before installation. Put your thumb over the bottom hole, Fill with oil and with your other thumb to push the oil through and then install the bush. You can see the oil on the outside of the bush if you do it right. Never had a problem.
#7 mugginz
mugginz
  • 230 posts
  • Name:Greg
  • Car:LH Torana
Posted 12 April 2019 - 07:41 PM
Think I'll go with this approach.
#8 rexy
rexy
  • 2,473 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 12 April 2019 - 11:21 PM
The instructions in the ancient days for the sintered bronze spigot bushes was to soak overnight in oil.
Never had an issue with clutch contamination.
You do of course wipe it “clean” before installing.
#9 mugginz
mugginz
  • 230 posts
  • Name:Greg
  • Car:LH Torana
Posted 13 April 2019 - 08:18 AM
That's a point that should be highlighted
#10 76lxhatch
  • 6,575 posts
Posted 13 April 2019 - 01:58 PM
I usually leave it standing to drain excess oil for a while after soaking overnight too.
#11 SWOOP74
SWOOP74
  • 52 posts
Posted 21 April 2019 - 08:09 PM
I remember my boss who did his mechanics apprenticeship in Italy and worked for Muir’s in Haberfield during the late 60’s and though to the late 70’s
He then opened his own work shop, i started there as an apprentice and worked for him for 10 years,
Any way i remember we always had a glass jar that was full of oil and sintered brass spigot bushes, so when required which was quite often in those days
Just fish out a bush give it a quick wipe, and never had an issue.
