Over carburated ?
18 replies to this topic
#1 limo
limo
  • 2,672 posts
Posted 15 April 2019 - 06:03 PM
went to old style boat races yesterday
boats from the 60s and on still in good nick and running
lot of memories
this one from 86 , 1500 hp stated, went like crazy
Attached File  IMAG0837.jpg   301.2K   17 downloads
named Insanity
some cars there as well but no Toranas, might take a couple next year
Attached File  IMAG0836.jpg   326.71K   13 downloads
but thought carbies bit much
Attached File  IMAG0835.jpg   367.49K   23 downloads
another
Attached File  IMAG0834.jpg   460.8K   14 downloads
Attached File  IMAG0833.jpg   379.91K   19 downloads
#2 claysummers
claysummers
  • 3,328 posts
  • Name:Clay
Posted 15 April 2019 - 07:44 PM
That’s Glen and Micks cars. Glen’s full house, accumulator, crank trigger etc. definitely not over carbed with the triple Weber’s. Micks is a 390, best carb on a warm six.
#3 _Lazarus_
_Lazarus_
Posted 16 April 2019 - 07:25 AM
Is that two 390s on a Grey six ?
#4 lx308
lx308
  • 2,838 posts
  • Name:Tony
  • Car:2005 CV8 Monaro
Posted 16 April 2019 - 08:57 AM
Looks like 2 carbys to me
#5 claysummers
claysummers
  • 3,328 posts
  • Name:Clay
Posted 16 April 2019 - 09:22 AM
He only had one on there last I looked. It’s a red. Yes that might be over doing it. I don’t think he would run it down the strip but Glens sedan does. 173 block bored and stroked to 202. Shortened Borg Warner rear, manualised trimatic, landcruiser front calipers, p76 rotors, unboosted.
#6 myss427
myss427
  • 1,636 posts
Posted 16 April 2019 - 02:55 PM
800 cfm on a 6 cylinder streeter? Guys with hot 308's get bagged for that much cfm.
#7 claysummers
claysummers
  • 3,328 posts
  • Name:Clay
Posted 16 April 2019 - 04:46 PM
I’m told not by the owner that it apparently runs well and is fairly economical so there you go. I would have thought twin strommies would be more so.
#8 _Lazarus_
_Lazarus_
Posted 16 April 2019 - 06:48 PM
Would be interesting to know if the 173 is definitely a red motor and if so what date it was manufactured.
#9 claysummers
claysummers
  • 3,328 posts
  • Name:Clay
Posted 16 April 2019 - 11:18 PM
173 cast in usual spot as I recall, not 2.8. Therefore a red.
#10 claysummers
claysummers
  • 3,328 posts
  • Name:Clay
Posted 17 April 2019 - 08:19 AM
Correction....
Blue 173 block from a WB ute with blue 202 crank.
#11 hz202redman
hz202redman
  • 3 posts
  • Name:Jason
Posted 11 July 2020 - 09:37 PM
I can put my bit in on the twin 390s.... I helped fit them as an experiment with the guy who has the black FB, they started 1st turn of the key and ran like a swiss watch, never going to be a world beater as too much CFM but looked different and actually worked good. The big problem was weight and keeping manifold gaskets tight on it. As far as I know its back to the single 390 again for now. Glens with the tripple webbers is an animal! It flys! deffo not over carbied that one.
#12 claysummers
claysummers
  • 3,328 posts
  • Name:Clay
Posted 12 July 2020 - 02:00 AM
Yes Glens FB is a serious beast
#13 yel327
  • 13,081 posts
Posted 12 July 2020 - 07:51 AM
Correction....
No such thing as a WB 173. 173/2.8 was dropped from Holden back in HJ. Only blue 2.85 was in Commodore.
#14 claysummers
claysummers
  • 3,328 posts
  • Name:Clay
Posted 12 July 2020 - 09:14 AM
Just what Glen told me. Anyway is a blue 173 out to 3 5/8” and 202 crank.
#15 yel327
  • 13,081 posts
Posted 12 July 2020 - 09:28 AM
RS2000 pistons I think they can use from an old memory
#16 _Lazarus_
_Lazarus_
Posted 12 July 2020 - 12:58 PM
3 5/8's is 202 bore.
#17 yel327
  • 13,081 posts
Posted 12 July 2020 - 01:22 PM
Which makes it a 202, but if you don’t want to bore that far an RS2000 pistons is the right in height from memory at a smaller bore.
#18 claysummers
claysummers
  • 3,328 posts
  • Name:Clay
Posted 12 July 2020 - 01:24 PM
Yes and 186. So maximum standard bore size. A reason why used 173 and used to be 179 were a good option for rebore. Bore to 3 5/8. Fit new pistons.
Hadn’t seen your post Byron.
#19 yel327
  • 13,081 posts
Posted 12 July 2020 - 02:02 PM
3.575” for the RS2000. Pretty sure they have the same pin height as a 202. Can get them forged too from memory.
