LS conversion into VK power steering automatically goes to full lock to the right hand side
24 replies to this topic
#1 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 22 April 2019 - 10:39 AM
Hey guys
I'm doing an LS conversion in a VK I have fitted avl power steering rack running off the l 98 power steering pump I've turned the car over for the first time and automatically the car goes to full right hand lock what would be my possible problems is there a possibility that I have the lines incorrect and by that I mean the pressure line to the return line which one is the pressure line is the pressure line the small one at the top on the VL power steering rack anyway any help would be appreciated guys
#2 bat 53
bat 53
  • 521 posts
  • Name:albert
  • Car:lc gtr
Posted 22 April 2019 - 10:58 AM
g'day jonesy
i hope youv'e got approvel because i have had to remove a 6lt from a vk and put a ls1 in because of the 180kw per ton
back to the Q the 5/8 nut is the high pressure line
cheers  bat
#3 S pack
  • 15,764 posts
My Ellery's Commodore workshop manual only covers up to VK. It shows the uppermost connection to the rack is the fluid return line to the pump and the lower connection is the pressure line from the pump.
#4 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 22 April 2019 - 11:28 AM
g'day jonesy
cheers bat
Thanks for your comment mate p.m. me if you want any more details but it is an l98 power steering pump
g'day jonesy
cheers bat
Hey bat is the 5/8 nut the top one just so I don't have to go out to the shed and double-check it straight away only because I've changed all the fittings
Edited by jonesy, 22 April 2019 - 11:29 AM.
#5 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 22 April 2019 - 11:34 AM
I appreciate your reply here the VL rack I think was the first one to start running two ports the VK from memory runs 4
I'm wondering whether it's got an airlock or the pressure from the pump is too high and I need some sort of restricting valve I'm hoping there's a power steering guru out there that can help me..
I do appreciate any replies they guys anything can help
This is a VL power rackand sadly I don't have the lines here to trace back which one is which but I was pretty confident that the top one closest to wear the intermediate shaft meets was the powerline
Bugger my picture did not upload
#6 bat 53
bat 53
  • 521 posts
  • Name:albert
  • Car:lc gtr
Posted 22 April 2019 - 11:36 AM
yes top one
#7 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 22 April 2019 - 11:40 AM
Vl rack
thank you for your reply if it is the top one I've got it connected to the right area now hopefully someone can tell me for what reason it wants to turn the wheels to full lock right hand down
Edited by jonesy, 22 April 2019 - 11:42 AM.
#8 bat 53
bat 53
  • 521 posts
  • Name:albert
  • Car:lc gtr
Posted 22 April 2019 - 11:42 AM
if you've had new line made was a restrictor tube fitted in
if not it needs one don't use plastic because they melt
if you have an old pressure line cut the hose you will see it
#9 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 22 April 2019 - 11:48 AM
Well that would explain it whereabouts is the restrictor
#10 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 22 April 2019 - 11:51 AM
Is it somewhere in here
#11 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 22 April 2019 - 11:53 AM
Does anybody know of an aftermarket one that would work with my setup would be nice if I could screw it into these lines
#12 76lxhatch
  • 7,222 posts
Posted 22 April 2019 - 11:57 AM
It will be a problem with the valve in the steering rack, doesn't matter how you supply pressure to the rack it shouldn't do anything by itself. Common problem in some of the older Falcons if I recall correctly.
#13 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 22 April 2019 - 12:10 PM
So this restrict. Won't be an issue is that not a worry for me the rack was meant to be working perfectly fine when it came out of the other car but that's a likely story I suppose
#14 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 22 April 2019 - 01:36 PM
That doesn't even make sense what I wrote The last Post
so this restrictor that is talked about is not required or is required to go into the lines?
Or if the rack has a faulty valve this could be the issue?
Has anybody else come across this issue with the rack going full right hand down..
I have another rack here that I can put in but I would prefer if I didn't have to as you could imagine it is a rather large job because I've got to remove the extractors the exhaust the intermediate shaft drop the tie rodsand undo the fittings in the extremely tight position...
I also thank everyone for the help on this subject
#15 S pack
  • 15,764 posts
Posted 22 April 2019 - 03:36 PM
Surely a faulty rack wouldn't/couldn't be designed/allowed to default to right or left full lock. That would be certain death at speed.
There must be something else going on and not a faulty rack.
#16 ozyozyozy
ozyozyozy
  • 953 posts
Posted 22 April 2019 - 04:14 PM
Sounds like the hoses are on the wrong way.
Did this with a rack of another make, did same thing.
Edited by ozyozyozy, 22 April 2019 - 04:14 PM.
#17 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 22 April 2019 - 05:03 PM
Hey boys just an update I change the rack out and all is fine so it must have been a faulty valve in the rack so good work 76lxhatch
#18 76lxhatch
  • 7,222 posts
Posted 22 April 2019 - 06:27 PM
They generally only do this slowly and you can still override with the steering wheel. Like any leaking valve it will only leak a small amount so you can still open it further or open in opposite direction to get different actions. Its the only way that assistance can be provided without input shaft movement.
#19 S pack
  • 15,764 posts
Posted 23 April 2019 - 07:42 AM
Ok, I was picturing the rack slamming to full RH lock the moment it was pressurised by the pump.
Dave.
#20 bat 53
bat 53
  • 521 posts
  • Name:albert
  • Car:lc gtr
Posted 23 April 2019 - 10:08 AM
This is the restrictor at rack end
What I am led to believe by the bloke that does my high pressure hoses without it it will want to turn and act as if you have huge amount of bump steer
Cheers. Bat
#21 Dr Terry
Dr Terry
  • 3,342 posts
Posted 23 April 2019 - 11:03 AM
The restrictor is to reduce noise, nothing more. It's more of a 'tuning' device.
If you leave it out, you will notice noisier operation, but it won't effect the power assistance.
Dr Terry
#22 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 23 April 2019 - 12:47 PM
^ Yes exactly, we have had to make p/s lines at work for various cars (usually older or rare cars that oe hoses are nla) and if the restrictor is left out it just increases pump noise. If it is too loud there are a variety of inline adjustable hydraulic restrictor fittings on the market.
#23 rodomo
  • 18,063 posts
Posted 23 April 2019 - 08:52 PM
All from memory...…………….
The steering rack PINION is in two parts with a torsion spring between them.
The torsion spring allows a tiny bit of movement of the steering wheel before power assist is activated.
This is so when driving in a straight line at speed you are not always correcting the steering wheel.
If that torsion spring breaks, the rack will have a mind of it's own sorta? The valve can be a tad open without touching the steering wheel.
Where the yellow arrow points here:
Edited by rodomo, 23 April 2019 - 08:53 PM.
#24 axistr
axistr
  • 1,224 posts
Posted 30 May 2019 - 06:58 AM
Most likely one of the plastic seals in the rotory valve leaking or a bit if metal has got into the valveing causing the valve to supply pressure to one side.
#25 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 27 June 2019 - 10:07 AM
good info here boys
