Hi Guys,
What is the best way to dissolve the glue on the pivots, without damaging the glass.
I want to rechrome the pivots.
Cheers Graham.
LJ quarter window pivots removal.
gad05
, May 11 2019 12:07 PM
5 replies to this topic
Posted 11 May 2019 - 12:07 PM
Posted 11 May 2019 - 01:17 PM
Try some acetone, don't know if it will work but you can only try.
Posted 18 May 2019 - 01:40 PM
Tried the acetone no joy.
Does anyone have a solution out there?
Posted 18 May 2019 - 02:48 PM
You could try a little heat , maybe a heat gun , but be careful not to use too much , you don't want to use too much and crack it.most of the fittings on mine were loose anyway , once the screws have been removed a gentle tap may take it off the glass .
Posted 18 May 2019 - 05:28 PM
Tried the heat gun, worked a treat, great result.
Thanks Paul
Thanks Paul
Posted 18 May 2019 - 05:52 PM
No worries good to hear!
